Go to Post Heck, every human being has the potential to change the world, as long as the world still exists. - [more]
Unread 26-01-2007, 17:55
Rinaldi 427's Avatar
Rinaldi 427 Rinaldi 427 is offline
any help but programming
AKA: Angelo Rinaldi
FRC #1482 (the ghosts)
Rinaldi 427 is an unknown quantity at this point
1482 Help with Compressor
We need to know if using 2 compressors simultaneously is allowed during the competition. Thanks
team 1482 proudly Canadian. proudly student built
Unread 26-01-2007, 17:58
Re: 1482 Help with Compressor
I don't think so. However, as far as I know, there is no rule specifically allowing or disallowing it. (Somebody will probably prove me wrong shortly, but I don't really mind.) I'd ask Q&A.
What would you want 10 pounds of compressor for, anyway? (Yes, that's about 5 pounds/compressor.)
Unread 26-01-2007, 18:58
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Did you get 2 compressors in your kit? I should think not. A compressor is considered another motor and another non-legal item. Simply put it would not be legal.
I do have to wonder though, why would you want another compressor on board?
-Mike
Unread 26-01-2007, 19:09
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
to make a faster lift of course.
Unread 26-01-2007, 19:30
AKA: Angelo Rinaldi
its to help our lift since today we got an e-mail saying that we cant use the cylinders we ordered from bimba and now its making life difficult for us and we might have to use a 2'' bore which uses more air than we have
Unread 28-01-2007, 18:25
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
I believe you're allowed to use up to 4 of the clippard tanks this year. Have the compressor feed into these tanks at 120psi and then use the fixed regulator to lower the operating pressure of your pneumatics to 60 psi or less. The stored air in the tanks should provide enouogh volume to drive what you need.
Check the pheumatics manual for help in setting up the system.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 30-01-2007, 23:49
AKA: Angelo Rinaldi
thanks but i dont need help with any of that i have done the math and we would need 78% more air to go 12'' and we are already useing four tanks at 125 psi we have contacted first and we are not alowed to use two comprresors
Unread 31-01-2007, 07:46
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Does lowering the pressure to, say, 30 psi rather than 60 then make you have enough air, or would 30 psi not give you enough power?
Also, depending on how close you are, you may just have to start your lift with 15/20 seconds left in the match so it has time to get filled all the way by the end.
part shipment help 1482 ! Rinaldi 427 General Forum 0 25-01-2007 02:22
somebody help me with my compressor please royboards05 Pneumatics 4 19-02-2005 00:38
Help With Compressor Code fred Programming 6 21-01-2005 17:40
Problem with compressor Nick R. Pneumatics 3 21-02-2003 10:51
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
