Go to Post I understand that Dean Kaymen has now invented a super "sniffer" that can scout-out anyone within hearing distance that is remotely-involved with FIRST. - dhitchco [more]
Unread 26-01-2007, 18:28
Team Update #6 is Out
Team update #6 is on the FIRST website: http://www2.usfirst.org/2007comp/Upd...pdate%2006.pdf
No major changes, just some clarifications.
Unread 26-01-2007, 18:34
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: Update 6 is out
No major changes?!
The Autodesk Visualization Design Award for Regional Competitions has been posted under Section 5 of the 2007 manual,
That's major.
http://www.usfirst.org/uploadedFiles...on _2007_.pdf
Unread 26-01-2007, 18:37
Best Available Data
FRC #1778 (Chill Out!)
Re: Update 6 is out
Actually, there is a big update. Please, use your tether. Don't use your radios. If you lose control of your robot, your disable switch does not work until your controller reconnects with your OI, which can take several seconds.
Originally Posted by Update from IFI:
The 2007 Robot Controller has an issue where the Robot can continue to run for about 1 second (the lost Link timeout) after a Link has been lost. The Robot will continue to execute the last 2 received commands repetitively (a run-on condition) until the lost Link timeout occurs. If the RC is intermittently missing data packets, the run-on can be extended to a few seconds. An example would be where the Robot may be running at a maximum speed when missing data occurs resulting in the Robot continuing to run at maximum speed for a few seconds. We recommend Tethering for your prototyping until this issue is corrected.
Unread 26-01-2007, 18:39
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Re: Update 6 is out
A very important IFI notice that some teams including ours, is having a very hard time with.
Hope it doesnt happen to a rookie team who may not have last year's radios.
Unread 27-01-2007, 13:58
Shelbo's Avatar
Shelbo Shelbo is offline
AKA: Shelby
FRC #0316 (LuNaTeCs)
Shelbo is a name known to allShelbo is a name known to allShelbo is a name known to allShelbo is a name known to allShelbo is a name known to allShelbo is a name known to all
Send a message via AIM to Shelbo
Re: Update 6 is out
In update 6 it states;
"The sprockets provided in the 2007 Kit of Parts were custom manufactured for FIRST and
are not COTS parts. As such, only the two 24-tooth sprockets received in the Kit may be
used on your Robot. Teams are welcome to fabricate equivalent parts from COTS items.
Comparable COTS #35, 24-tooth sprockets are available from vendors such as Innovation
First, McMaster-Carr, and others. You may have to make modifications to these sprockets
in order to mount them to your wheels, get sufficient spacing for your chain, etc. In this
scenario, the additional sprockets would be considered modified COTS items."
Our team custom-made a sprocket with more than 24 teeth (not sure of the actual number). According to the parts use flowchart it is legal, according to the update it appears that it is not. Which is correct?
~Some people dream of worthy accomplishments while others stay awake and do them.~Anonymous(crunch weekend)
~SPACE PANTS!!!
(whats underneath???)
Unread 27-01-2007, 14:07
dtengineering's Avatar
AKA: Jason Brett
Re: Update 6 is out
If you custom build something such as a sprocket during the build period then -- subject to cost and other rules -- it will be legal.
All they are saying, I believe, is that you cannot use (even if they are given to you from another team) more than two of the KOP sprockets.
Custom building is generally very much encouraged!
Jason
Unread 27-01-2007, 15:45
Barry Bonzack's Avatar
Barry Bonzack Barry Bonzack is offline
Impossible to rain on my parade.
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack
Re: Team Update #6 is Out
They noted the interest in keeping the regional award. Way to go to everyone that has made their voices heard in this thread to get this award back. How many teams are going to start working on their animation now with half of the build season gone though? Even if your animation is completed, I fully suggest all animation teams go for this award even without the time that is missing.
Chair of Florida FIRST Alumni
Orlando Regional Planning Committee
FIRST Tech Challenge Florida Leadership Team
Program Planner on the Orion Spacecraft at the Kennedy Space Center
Twitter: @FL_FIRST_Alumni
Events I'm Emceeing/Game Announcing:
1/10/2015 FTC Jacksonville League Championship
1/11/2015 FTC Central FL Tesla League Championship
1/17/2015 FTC South Florida League Championship
1/24/2015 FTC Tampa/St. Pete League Championship
2/7/2015 FLL Orlando Regional
2/14/2015 FTC State Championship
2/26-2/28/15 FRC South Florida Regional
3/8/2015 FLL State Championship
3/12-3/14/15 FRC Orlando Regional
4/22-4/25/15 FIRST World Championship Event - FTC Franklin Field
Team update #2 is out Aaron Lussier General Forum 1 09-01-2003 17:50
Team Update #1 is out Bill Gold General Forum 32 08-01-2003 07:55
Team Update #6 is Out! archiver 2000 10 23-06-2002 22:53
Team Update #5 is out! archiver 2000 3 23-06-2002 22:49
Team Update #4 is Out! archiver 2000 3 23-06-2002 22:45
