Go to Post That statement makes far too much sense for me to understand it. - Aignam [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 26-01-2007, 19:17
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: Labview and communication with peripheral device help
In LabVIEW we use a single VI for write, and a single VI for read. So, if you want to talk to a device, you would "write" your 2-character string to issue a command to the device, and then you would "read" a 2-character response from the device. The CMUCam2 camera communicates via serial in exactly the same way.
If the response is always known, but you just need to issue the command and wait for it to be executed, I would recommend just using the VI included in the CMUCam2 library called, "query for result from serial port.vi". This function is very nice because you can input what the command is, what you expect back, and you can provide a timeout in case it doesn't give you what you expected in the time specified.
If the response isn't always know, but the byte size is, then just use the primitive read/write functions - write your 2-byte string, then read up to 2 bytes from the serial port. It's fairly straightforward.
If you need examples, give me an example of what you're trying to do (exact communication) and I'll show you how it should look in LabVIEW.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Serial Communication Problems with LabVIEW FRC Toolkit Jon236 LabView and Data Acquisition 1 28-12-2006 11:57
CMU Cam2 Java app (Help with Labview GUI) Team 1649 Programming 3 26-12-2006 14:25
organized way of communication with FIRST? archiver 2001 0 24-06-2002 04:20
Help with Autocad and Bryce 5 Keith Chester Inventor 0 25-03-2002 17:33
