Go to Post It never stops. Championships will be in your head forever!!! MWHAHAHAHA!!! - vadyr [more]
Unread 26-01-2007, 19:23
AdamHeard's Avatar
Lead Mentor
Buying steel #25 sprockets
I'm looking for steel, flat, #25 pitch sprockets in 48 and 70/72 tooth.
Mcmaster only has these with hubs. I need them to be flat so because they will be welded onto a tube. We can buy the hubed ones and machine them off, rebore them and try to find a way to weld the hardened steel, but I would rather just buy the right thing in the first place...
so... where should I look?
Unread 26-01-2007, 19:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Buying steel #25 sprockets
SDP-SI has them in carbon steel.
Unread 26-01-2007, 21:20
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
That's http://www.sdp-si.com just in case Google is suffering from amnesia.
Unread 27-01-2007, 17:33
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Check out Motion Industries.
Part# 25A40 pitch (A)hubless/(B)hubed number of teeth
Martin's Sprocket Catalog
Check out page 16.
Welding stainless steel to mild steel... can it be done? Travis Covington Technical Discussion 3 27-01-2004 19:11
Steel Blends Wetzel Technical Discussion 2 15-09-2003 17:01
steel tubing BBFIRSTCHICK Rules/Strategy 2 14-01-2003 22:03
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
Steel Edge AJ Howard Rules/Strategy 1 18-01-2002 18:52
