Go to Post Thank you FIRST -- thank you, thank you, thank you -- I can't say that enough. We can't say that enough.... Its too bad that more of us don't try. - Aidan F. Browne [more]
Unread 26-01-2007, 21:46
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
pic: All folded up
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: pic: All folded up
love the diamond plate.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 26-01-2007, 21:48
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
That diamond plate must make for one EXPENSIVE robot.
Unread 26-01-2007, 21:52
in between teams
AKA: Luke Van Oort
9 feet long? Wow, thats huge! What are you planning on to power the unfolding?
Team 1219: 2009 - Mentor
Unread 26-01-2007, 22:03
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
The 64:1 banebot gearmotors ( one on each ramp) driving lead screws drive each ramp over center where they fall to the carpet. The big ramps fall is cushioned by a "pool noodle" and the small ramp by dense foam. Works great but you don't want to be in the way when they deploy.
Unread 26-01-2007, 22:09
DonRotolo's Avatar
Back to humble
FRC #0832
Watch out for crosswinds!
Very nice. How much does it weigh??
Don
Unread 26-01-2007, 22:31
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
75 LB minus the electronics
Unread 26-01-2007, 22:34
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
Its cute.
so yall going 6' and 100Lbs
are yall planing on having a arm??
Unread 26-01-2007, 22:35
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Are you going to add some filler weight to bring it up somewhere near the limit for whatever class you're in? (What class is that, by the way?)
Unread 26-01-2007, 22:49
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Yes, we're going to be in the 6 ft 100LB category. We'll make sure it weighs very close to the max weight. With bumpers and the battery our weight will be 128 LB. We're going to play defense during the first part of the match. Can you imagine trying to see around a 72 inch by 38 inch piece of diamond plate between you and the rack? If we don't move at all from our starting position in the home zone and just deploy our ramps at the start of the match we've blocked the other alliance from getting to a lot of their tubes. With about 20 square feet of 12 inch high parking space we have plenty of easily accessible space for two robots.
Unread 26-01-2007, 23:48
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
What kind of hinges are you guys using to attach the diamond plate ramp? I see two there, they seem rather small too.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 26-01-2007, 23:54
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Hi Ryan, Both ramps are attached with two commercial grade 1 1/2 x 3 inch steel hinges ( about the only steel on the whole bot). The heaviest ramp is only 20 LB. To test the hinges and ramps we've had 200 plus pound boys stand on them with no problems.
Unread 27-01-2007, 00:03
Po-ser's Avatar
Po-ser Po-ser is offline
AKA: Polina Danilyuk
FRC #0694 (Stuypulse)
Po-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud of
Send a message via AIM to Po-ser
Very nice. What made you choose diamond plate? (Just curious about your thought process as you went about making the ramps.)
Aim for the stars, land in Hawaii.
2003 - NYC Regional winner
2005 - NYC Regional Woodie Flowers Award
NYC Regional Chairman's Award
Championship Galileo Division semifinalist
Unread 27-01-2007, 00:13
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Our team has always used diamond plate and it has kind of become our hallmark.
Unread 27-01-2007, 00:22
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
diamond plates are great.
thats what we are using also. 1/16" diamond plates are relatively light since they are stamped and provide some traction for robots to climb.
However, it costs a lot!
pic: 1!!1 ALL D0N3 MR ROBOTO!!!1!11!!!! QuantumNinja Robot Showcase 35 15-02-2006 21:03
pic: All bow to Ted sebas2mil Extra Discussion 4 15-07-2005 12:04
pic: Going all out on packing bombadier337 Extra Discussion 1 27-02-2005 00:10
pic: Look at all the totes!! CD47-Bot Extra Discussion 4 31-03-2003 13:21
Calling all Tigerbolt Chatters - And All Newcomers! Lora Knepper Chit-Chat 9 11-07-2001 18:09
