Go to Post Umm, guys, the stacking game was last year. Toss the Genia is much more appropriate for Aim High. - Greg Marra [more]
Unread 26-01-2007, 21:57
burkey_turkey burkey_turkey is offline
AKA: Andrew
FRC #0422 (MechTechs)
burkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to behold
small banebot motor with 64:1 gearbox
Im just wondering if anyone has tried using the small banebot motor with the 64:1 gearbox. We have a very light arm this year, and instead of using the 'pimp CIM' (the one with the spring and stuff) we thought we might be able to use the small banebot motor with the 64:1 gearbox. I saw some stats on it on the banebot website but i really dont know what that means or trust my own calculations. So, if any teams have experimented with this motor, i would to hear what your opinions on it are. How strong is it compared to other motorts in the kit? does it pull a fisher price and melt when it stalls? any comments on the motor would be apreciated, qualitative and quantitative.
Unread 26-01-2007, 21:59
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: small banebot motor with 64:1 gearbox
From our observations, the motor backdrives. And, for future references, your "pimp cim" is actually called a Minibike motor.
Unread 26-01-2007, 22:05
DonRotolo's Avatar
Back to humble
FRC #0832
It's pretty stong - we had a hard time stopping it from spinning. It rotates about 3-1/2 times per second, and that 3/8" shaft, with both a 1/8" keyway and a tapped hole on the end make it easy to mount to. And, the gearbox has those nice mounting holes... We'd been considering the globe motor - it runs at a more suitable speed for what we're doing with it - but went with the Mabuchi just because the 64:1 gearbox & shaft is so nice to work with.
We ran ours in for about an hour, no load current draw went from almost 2 amps down to just over 1.
It does backdrive, can be a disadvantage in some applications.
Don
Unread 26-01-2007, 22:13
AKA: Andrew
sorry, but im new at this, so when you say it backdrives, does that mean that if i had the motor connected to some arm (via chains) and i lift it up and stop it, pressure on the motor can make it wander backwards and fall some? if i put just a little bit of current through the motor or something would the problem be fixed?
Unread 26-01-2007, 22:36
FRC #0701 (RoboVikes)
No, it is probably not going to be feasible to apply a "small amount of current" to keep it from moving.
Different angles of the arm result in a different amount of force being applied in the downward directions. Thus one amount of current may hold it in place, but at a different position it would do nothing or even cause the arm to move.
The only feasible solution is monitoring arm position via a Pot (recommended!)
or using a locking worm gear transmission ( this will work but I wouldn't implement a worm gear simply due to the fact that it locks... maybe if you need a massive reduction with small amount of space
Team 701
Unread 26-01-2007, 22:45
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
http://www.chiefdelphi.com/forums/sh...&highlight=PID
That thread should help out a bit
But in a rough case, yes, you can run the motor a bit and keep the arm in a fixed position, We've had to do it in the past.
Unread 26-01-2007, 23:06
AKA: Andrew
one final big questino i have thats been neither confirmed nor denied, is if the motor mentioned in these posts can burn up real easy like the fisher price motor when stalled. This could be a real problem, so im trying to get all the info i can before we make a decision. thank you everyone for your contributions so far, you dont know how helpful youve been, honestly.
Unread 26-01-2007, 23:47
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
I wouldn't be surprised for it to burn up just like the FP motor, most small high RPM motors will have that same problem. This new motor looks just like a weaker FP motor. You would be better off with approx. twice the torque with the FP motor, and a 42mm banebots gearbox. I am liking this 256:1 42mm gearbox to attach a FP motor for an arm.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 26-01-2007, 23:55
AKA: Andrew
thats the 550 motor not the 540 that was included, is that legal?
Unread 27-01-2007, 00:14
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
The motor is not legal, but the gearbox that is attached is legal. You may be able to use the FP motor in that gearbox.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 27-01-2007, 04:10
meiv4 meiv4 is offline
The Jimmy
AKA: Jimmy Dolengewicz
FRC #1388
meiv4 is on a distinguished road
Send a message via AIM to meiv4
The FP motor will fit in the 42mm gearboxes. you either have to pull the pinion gear off the motor that comes with the gearbox or buy another one just get the right one for whichever box you get. The shafts are also a hair long so you will need to add some small spaces when mounting or cut down the shaft. One idea we were looking at was getting 2 of the 27:1 gearboxes and then using both FP's to dual drive a worm gear for our arm, although almost every member of the team hates the FP motors, which is not cool since a good 3/4 of them are freshmen and have never seen them in action.
pie = 8.53973422
Unread 27-01-2007, 20:35
AKA: Andrew
so one last question in my never ending struggle of finding the right arm motor, can the fisher price mini bike motor can go through the same gearbox that the CIMs go through? if this is true than my work is practically done for me:
2700 rpm -> 45rps
12:1 gearbox -> 3.75rps
the 4:1 attachment -> ~1 rps
some procket reductions (1 or 2) and its at a reasonable speed!
the minibike motor seems like its CIM ish enough to fit in one of those, but we are already using both of our gearboxes for the drive and cant test to see if it works cause its already assembled. it would be nice to know if it would work before we buy the gearbox.
Unread 29-01-2007, 01:48
AdamHeard's Avatar
Lead Mentor
Team 294 agrees with you.... Three times to be precise....
Low enough gearing combined with a PID algorithm (which is much simpler than you may think) will work.
opening up the BaneBot gearbox to install the CIM motor jskene Motors 9 22-01-2007 11:12
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
Drill Motor Max RPM with Gearbox? archiver 2001 1 23-06-2002 22:40
What with the small motor? Robb Gerber General Forum 10 10-01-2002 14:10
