Re: Digital to OI Analog
I could certainly use the digital inputs, but it would be a waste at only 16 available bits (I'd need to multiplex, and for that I'd need to either synchronize to the packet stream or go real slow, which would be a pain)
The digital pots do look like a good solution, and they're not too expensive either. Specifically, these (from Microchip, hah) look like a pretty good choice at $2.65 each (we'll probably use three or four of them to give 6 or 8 inputs). http://www.digikey.com/scripts/DkSea...604125&Site=US http://ww1.microchip.com/downloads/e...Doc/11195c.pdf Thanks for the answer! I'd completely forgotten about digital potentiometers. Out of curiosity still though, does anyone know what the input section of the OI looks like? |
If you choose to use the digital pots, make sure you read the data sheet very carefully. They have a tolerance of +-30%. So that means you could get a pot that has a value of 70k to 130k. Also in order to use the pots you must interface the to a device with SPI or I2C. Another words you will need a processor. Processors need power, usually more than the 10mAs supplied by the digital outputs. In short you will need an external power source, which you know, is illegal. This is one of the difficulties that we were faced with when developing the Chicklet. |
Also, if we really wanted to use a high-current custom circuit, we could just buy the USB-Chicklet, and use it and a USB PIC to get 500mA. |
Actually you are over estimating the power output of the joystick port. I'm not quite sure were the 100mA is coming from. I assure you it is not from the joyports. LED Drivers (see pinouts on pages 7-10) PORT 1 and PORT 3 each provide four LED output drivers. These LED drivers allow the connection of external LEDs that duplicate the function of the top eight Robot Feedback LEDs on the Operator Interface. The LED drivers provide 5V that is current limited to 10mA. Connect the LED’s anode to the desired LED drive pin. Connect the LED’s cathode to any ground pins. The LED drivers are the only way for you to get Power. They are limited to 10mA. If you are thinking of using the 5Vaux pin, that is limited to a value in uA. So unless you are sleeping your processor 90% of the time, you can not get enough power to run your device. Trust me, If there was a way to get power off of the O/I we would have. I guess if you can get your power consumption below 10mA you would be ok. But you still have to deal with the abysmal tolerances of the MCP42100. |
Mike,
The 100ma is coming from the OI reference Guide. It says the current limit on the +5V aux pin is 100ma for all 4 ports. If the practical limit is significantly lower than this by a factor of 10 for some reason... well it'd be nice to know, and it'd be nice if IFI updated the reference. EDIT: Finished your post. MICROamps on the 5V aux? The reference clearly says 100mA. If the limit is truly microamps, then IFI really needs to update this document. Last edited by Kevin Sevcik : 27-01-2007 at 01:05. |
well Ill give credit to where credit is due.
the reason I suggested using a digital pot is because I spent most of last semester(in bits and peaces on weekends) building team lightnings ps2-15pin analog adapter. so not only is it possible to run digital pots with a micro controller . . its been done and tested. Last edited by Stuart : 27-01-2007 at 01:29. |
#7
I just tested my OI to 100mA from Port 1 Aux (pins 1 and 4) running two (overloaded) white LEDs. Multimeter measures 100mA, voltmeter measures 4.5V. Okay, so the voltage does drop a bit, but I intend to run 3.3V circuitry using a switching buck regulator anyway, and 4.5V will still work fine for most 5V ICs too. My calculations say worst-case the aux circuits will draw 100mA at 3.3V, which is 66mA at 4.5V and 60mA at 5V (remember, this is a switching regulator, not a linear one, so it ideally does not waste any power). Even with some extra stuff thrown in (LEDs, DC-DC inefficiency, etc), I still have room.
#8
You may get lucky for about a minute of continuous use, but I assure you you will be operating the O/I out of spec. A good design sould be created so that it meets the specs called out by the data sheets and operational specifications. If your TOTAL current consumed by ALL 5v AUX pins is greater than 100mA you run the risk of the voltage being clamped to 300mV. We have done extensive testing with the O/I and this does happen. |
#9
I was basing the aux rating on information given to me by IFI. And you should read this more carefully. [5] The current limit of the +5V Aux from all 4 ports is about 100mA. The Aux Fault Led will start illumination when the current draw from the +5V Aux Outputs total about 120 mA and the +5V Aux voltage will have dropped to about 4.5 volts. Worse case, short condition: after about 30 seconds, the voltage will be at about 300 mV with a current of about 250 mA. The limit from ALL FOUR PORTS is 100 mA. (This means all four added together.) When the outputs exceed 120mA the Fault LED will Illuminate. And it clearly states that after 30 seconds the voltage will be clamped to 300mV. If you do further testing you will come to the inevitable conclusion that you cannot get 100mA from one joyport continuosly. Last edited by Mike Copioli : 27-01-2007 at 08:39. |
| Analog-to-Digital Converter Code | Kevin Watson | Programming | 29 | 17-02-2008 13:07 |
| Analog to Digital Conversion Help | Der Rowan | Programming | 4 | 23-01-2006 00:17 |
| Accelerometer: Analog or Digital? | psquared | Programming | 2 | 10-02-2005 16:38 |
| Analog / Digital IO Connectors | Aidan F. Browne | Control System | 4 | 06-02-2005 22:26 |
| Analog vs Digital inputs? | f22flyboy | Programming | 8 | 08-11-2002 22:18 |
