Go to Post Yes, no more dancing. Robots is serious business :rolleyes: - wilsonmw04 [more]
Unread 26-01-2007, 22:32
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: Digital to OI Analog
Originally Posted by marcan View Post
The digital pots do look like a good solution, and they're not too expensive either. Specifically, these (from Microchip, hah) look like a pretty good choice at $2.65 each (we'll probably use three or four of them to give 6 or 8 inputs).
http://www.digikey.com/scripts/DkSea...604125&Site=US?
http://ww1.microchip.com/downloads/e...Doc/11195c.pdf
If you choose to use the digital pots, make sure you read the data sheet very carefully. They have a tolerance of +-30%. So that means you could get a pot that has a value of 70k to 130k. Also in order to use the pots you must interface the to a device with SPI or I2C. Another words you will need a processor. Processors need power, usually more than the 10mAs supplied by the digital outputs. In short you will need an external power source, which you know, is illegal. This is one of the difficulties that we were faced with when developing the Chicklet.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Analog-to-Digital Converter Code Kevin Watson Programming 29 17-02-2008 13:07
Analog to Digital Conversion Help Der Rowan Programming 4 23-01-2006 00:17
Accelerometer: Analog or Digital? psquared Programming 2 10-02-2005 16:38
Analog / Digital IO Connectors Aidan F. Browne Control System 4 06-02-2005 22:26
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
