Go to Post Parking Lot T-Shirt Bootleggers are NOT approved suppliers - Rich Kressly [more]
Unread 26-01-2007, 21:52
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
pic: MiniMe
Unread 26-01-2007, 21:54
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: pic: MiniMe
Did you find that the diamond plate provided an adequate grip for robots to climb up? For some reason, in my mind diamond plate equals slippery, and im not sure if all robots will be able to climb that (Please correct me if I'm wrong).
Other than that, it looks great!
Unread 26-01-2007, 21:57
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Re: pic: MiniMe
Diamond plate is not all that slippery. We plan to sandblast the treads if we need to. Our ramp is 20 degrees and not that hard to climb.
Unread 26-01-2007, 22:17
flamefixed flamefixed is offline
FRC #0219 (Team Impact)
flamefixed is on a distinguished road
Re: pic: MiniMe
one of the characteristics of diamond plate, even if it is highly polished, is the raised diamonds give an incredible amount more traction than just plain sheet.
(just throwing that out there, random tid-bit)
Unread 26-01-2007, 22:32
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Re: pic: MiniMe
But not as much, as if it were treaded with conveyor belting or carpet, or something similar. Just a thought.
Unread 26-01-2007, 22:38
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: pic: MiniMe
hows the weight on that? It seems like it should weigh like 300 lbs it looks absolutly huge!
Unread 26-01-2007, 22:54
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Re: pic: MiniMe
Without electronics it weighs 75 LB. A piece od 24 x 48 inch diamond plate only weighs 7 LB. Our big ramp weighs less than 20 LB.
Unread 26-01-2007, 22:57
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Re: pic: MiniMe
Does it have room for 2 robots??
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 26-01-2007, 23:06
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: MiniMe
While Diamond Plate may give decent traction, a surface like carpet, rubber, velcro, or non-slip padding (like you put under rugs) may be far superior.
Unread 26-01-2007, 23:37
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: pic: MiniMe
Jonathan, if you refer to the other picture they uploaded, it seems like they have enough room for two robots. Good luck.
Unread 26-01-2007, 23:42
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Re: pic: MiniMe
Yes, Jonathan it has room for two robots with bumpers. The length of the flat portion of the ramp is 76 inches. The wheelbase on most robots is less than 32 inches and factoring in two bumper thicknesses of 2 1/2 inches each that still leaves about 6 inches excess ramp.
Unread 27-01-2007, 00:24
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
Re: pic: MiniMe
This looks like a solid robot that can add 60 pts to its alliance every time.
When I look at this picture at 100% size, it looks like the chain has less than 120 degrees of wrap on the drive sprocket. Does anyone else see this as a problem?
Unread 27-01-2007, 00:29
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: MiniMe
must be 16 gage, eh?
(for those who haven't played with the numbers, aluminum weighs 0.1 lbs/cubic inch, it's really easy to calculate the weight of sheets of aluimnum.)
Unread 28-01-2007, 16:44
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: MiniMe
Perhaps I'm misunderstanding something -- but robots with bumpers can be as long as 45 inches -- potentially requiring at least 90" of length atop the platform. Even if you assume that the first robot up's frame and front bumper overhang the end of the ramp, there's little chance that'll make up 14 inches of length.
What am I missing?
--Madison--
...down at the Ozdust!
Unread 28-01-2007, 16:47
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: pic: MiniMe
What am I missing?
I would argue that a skilled driver would be able to go up the ramp and then turn their robot sideways. It would be extremely tight, but even if a wheel overhangs a bit, there would still be boatloads of room for the second robot. Otherwise, you can allow for some amount of overhang on both sides of the ramp and fit two robots.
Hmm, how tall are the guard rails that border the field? I have a horrible picture in my mind of a robot escaping the playfield on one of these ramps...
