Go to Post Sometimes the best hiding places are in plain sight. - Robert Cawthon [more]
Unread 27-01-2007, 03:10
marcan marcan is offline
AKA: Hector Martin
FRC #2117 (Wolvotics)
marcan will become famous soon enoughmarcan will become famous soon enough
Re: Digital to OI Analog
I just tested my OI to 100mA from Port 1 Aux (pins 1 and 4) running two (overloaded) white LEDs. Multimeter measures 100mA, voltmeter measures 4.5V. Okay, so the voltage does drop a bit, but I intend to run 3.3V circuitry using a switching buck regulator anyway, and 4.5V will still work fine for most 5V ICs too. My calculations say worst-case the aux circuits will draw 100mA at 3.3V, which is 66mA at 4.5V and 60mA at 5V (remember, this is a switching regulator, not a linear one, so it ideally does not waste any power). Even with some extra stuff thrown in (LEDs, DC-DC inefficiency, etc), I still have room.
Analog-to-Digital Converter Code Kevin Watson Programming 29 17-02-2008 13:07
Analog to Digital Conversion Help Der Rowan Programming 4 23-01-2006 00:17
Accelerometer: Analog or Digital? psquared Programming 2 10-02-2005 16:38
Analog / Digital IO Connectors Aidan F. Browne Control System 4 06-02-2005 22:26
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
