Go to Post Changing the world starts with changing yourself. - Jeremy_Mc [more]
Unread 27-01-2007, 11:15
idahorobot's Avatar
idahorobot idahorobot is offline
FRC #2130 (Alpha +)
idahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the rough
Pressure Switch Wiring
I am not sure how to wire in the pressure switch for the pneumatics. The switch has two terminals the PWM digital has three. Do I use just the ground and positive?
Thank You
Unread 27-01-2007, 11:18
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Pressure Switch Wiring
You should connect the black wire to the C terminal, and the white wire to the NC terminal. The red wire is not used for hooking up switches.
EDIT: There is more info on page 9 of this document:
http://www.ifirobotics.com/docs/rc-r...-6-13-2006.pdf
Wire switches between the desired digital input signal pin and a ground pin.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Need Help Wiring Micro Switch/Limiting Switch Windward Electrical 2 07-02-2006 18:26
PRESSURE SWITCH Mr. Steve Pneumatics 20 01-12-2005 10:20
Pressure Switch wiring diagram robotjoe Electrical 1 08-02-2005 14:01
Pressure Switch Wiring Question Matthew_H Electrical 4 16-02-2004 01:25
Pressure Switch Wiring Question Matthew_H Control System 1 08-02-2004 15:28
