Go to Post I really think we need to keep our pitchforks sheathed and torches unlit until we here more news and get more details. - IndySam [more]
Unread 16-01-2007, 13:59
comwiz7's Avatar
comwiz7 comwiz7 is offline
AKA: Joey
FRC #1323 (Madtown Robotics 1323)
comwiz7 will become famous soon enoughcomwiz7 will become famous soon enough
Send a message via MSN to comwiz7
Camera Working...then mysteriously stopped
I had the camera working, used a tweaked version of Kevin's code, and then all of a sudden (with no changes or damage whatsoever) it stopped. Now instead of the green and red lights that were constantly lit before, there is one green light, and no movement of the camera. No changes were made to the robot or the code so what could be the issue??
Unread 16-01-2007, 14:13
razer razer is offline
FRC #1690
razer is an unknown quantity at this point
Re: Camera Working...then mysteriously stopped
I think your problem is that while the camera searching the target and turning around, the PWM wires which connected to the camera being disconnected, because the wire is too short, and suddenly it disconnect and you dont notice.
this problem accured to me many times, and it keep accuring.
Unread 16-01-2007, 14:21
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Check your back up battery. Remember, just like always, the Servos are actually powered by that battery. This bit us several times last season.
Additionally, the TTL board gets pulled off the RC easily. That also killed us last year too.
Unread 16-01-2007, 15:55
Electrical Engineer
Rookie Year: 1995
I agree with Mr. Bill... Your backup battery is a prime candidate.
Also, when resetting the robot via the RC reset button, press and hold the reset for 5 seconds. Last year's camera did not like quick resets and I assume that this year's camera may exhibit similar behavior.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 16-01-2007, 16:43
comwiz7's Avatar
AKA: Joey
Thanks, I'll try your suggestions after school.
Unread 16-01-2007, 20:18
comwiz7's Avatar
AKA: Joey
Nothing worked, The red light actually comes on for a second and starts to track, and then it stops and goes off.
Unread 16-01-2007, 20:36
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
(emphasis mine)
I'm going to bet that it has something to do with the code. What were the changes made to it, exactly?
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 16-01-2007, 21:11
comwiz7's Avatar
AKA: Joey
A lot changed but then I went back to the default and still nothing. It worked fine on default before.
Unread 16-01-2007, 22:06
Kevin Watson's Avatar
La Caņada High School
FRC #2429
If you're using the bells and whistles version, make sure nothing funky was left in EEPROM. You can just overwrite it or wipe it using the directions in the docs.
-Kevin
Kevin Watson
http://kevin.org
Unread 20-01-2007, 06:18
FRC #1690
i dont know why but now im having the same problem, i guess it is the backup batterry... because i was tierd of the camera i started to program something else, and then i saw that when i turn the RC off it turns off immediatly, not as before... it suppose to turn off after 5 seconds.
Unread 24-01-2007, 18:50
comwiz7's Avatar
AKA: Joey
OK, I've checked every possible thing, it seems like it's defective. Nothing works, I've even tried different servos! I really need some help!
Unread 24-01-2007, 19:10
destructorspace destructorspace is offline
FRC #0868
destructorspace is an unknown quantity at this point
it might be the ttl connector is loose... thats our problem. so if anyone has any simple solutions, please share!
Unread 25-01-2007, 16:24
comwiz7's Avatar
AKA: Joey
I don't think it's the TTL connector, this problem is really strange.
Unread 27-01-2007, 11:26
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
we we're running the light off of a battery at the beginning of the season and when the votage on the battery dropped slightly the light's changed slightly and the camera could not see it clearly. If you're doing the same thing try running the light off a constant power supply or change batteries often.
other than that I would agree with the backup battery thing stated above.
Unread 27-01-2007, 12:11
Athena Athena is offline
FRC #1676 (Pi-oneers)
Athena is on a distinguished road
yea. we have that problem a lot where the camera just stops even though the code is fine. it just takes patience and a lot of hard resets. turn off main battery and then disconnect backup battery. leave unplugged for a few seconds. plug backup battery in FIRST then main battery. do that a few times. press reset on controller. turn the camera on and off. and make sure the pwms arent the problem. they tend to go bad easily. so yea. hope this helps.
Use of a Camera other then the CMUcam bear24rw General Forum 9 09-01-2007 00:26
Camera not working in autonomous Roger Programming 9 09-03-2006 07:38
Camera isn't working Idaman323 Programming 13 15-02-2006 23:18
Camera code not working.... DemonYawgmoth Programming 5 11-02-2006 09:21
Camera not working st1nkm4n Programming 7 02-02-2006 08:22
