Re: Moving bot once targeted on the light
Thanks.I should of mentioned two other things also.
1.) When I tried the motor I had set it to 255. But that didn't anything obviously 2.) When the camera picks up the light, it will slowly (but jumply, and jitterly) tilt upwards. As it does this, the red light blinks, instead of steadily staying on. So I suspect that it only is locked on momentarily to light, not giving enough time change the values of the pwms(?). Sorry I didn't mention this in the first post. ![]() |
Ok, I fixed problem 2! I'm still unsure of how to actually move the robot now though.
Is your default_routine() call uncommented? If so, something might be mapped to those PWMs, and you might be getting interference between your code and the mapping in default_routine().
Nope, it commented out...
| Keepers in Teleoperated mode | burkey_turkey | Rules/Strategy | 47 | 05-03-2007 12:56 |
| camera trouble,cant tell the green-light from regular white light | Nimmy | Programming | 26 | 14-01-2007 14:53 |
| How will the Balls Change once FIRST Paints them | Mr.G | General Forum | 28 | 24-01-2006 23:07 |
| Moving the Nats. Date? | roboTICKS-236 | General Forum | 4 | 19-03-2003 22:49 |
| ONCE AGAIN, EVERYONE TELL ME THE ANSWER! =) | archiver | 2001 | 2 | 24-06-2002 02:42 |
