#16
Re: New version of WPILib
There are a few functions in WPILib which are hard for programmers to use, but easy for EasyC to automatically generate. These are two of those functions. The function: InitializeCamera(CameraInitializationData *c); that you can call passing the address of the camera initialization structure. This is probably easiest for you to use. The other function: InitCamera(unsigned char cameraInitIndex); was intended for EasyC. It assumes that there is an array of those structs and the argument is the index to the one you want to use. My suggestion is to initialize a structure with the camera parameters you want to use and call InitializeCamera. It's actually called from inside of InitCamera anyway. The other functions to use the camera data are: CaptureTrackingData(...) - this is the one you described and TPacket *CopyTrackingData(void); Is the function that I intended hand-coding programmers to use. This returns a pointer to a static structure containing a TPacket inside of WPILib. When you call the function, it turns off interrupts, grabs the most recent packet, and puts it into the static structure - then returns its address. Then you can write code like this: TPacket t = CopyTrackingData(); conf = t->confidence; which seemed to be pretty convenient. Last edited by BradAMiller : 07-02-2006 at 20:30. |
#17
Thanks for the info Brad... I think the time lag between coding and documentation is a law of physics. ![]() Steve |
#18
There is a new version of WPILib that has better error handling for the CMUCam. It will now fail more quickly if the camera is not detected and there is a function to get the status from the camera after initialization.
You can get it at the usual place. Please post something with your results. I have tested it on a 2006 controller with the camera disconnected from the serial adapter and also with the serial adapter disconnected from the robot and both seem to work. Be sure to save the old version this close to shipping in case you don't like the results. |
#20
Hey Brad,
Where do you find BuiltIns.h ? Your efforts are appreciated. |
#21
Whoops...
It's fixed now. There was a problem with the automatic build stuff and some stuff didn't update properly. The new version is in the usual place. Brad |
#22
Not quite fixed yet!!!
I get : You don't have permission to access /~bamiller/WPILib/WPILib2007011601.zip on this server. Kruuzr Quote:
#23
Same here. I'm getting the "You don't have permission to access /~bamiller/WPILib/WPILib2007011601.zip on this server." as well
#24
Fixed... sorry about that.
#25
#26
I put up a new version of WPILib that exposes some of the internal functions that can reset the camera and send commands to it. Should make it easy to use the Virtual Window stuff.
http://users.wpi.edu/~bamiller/WPILib/Versions.html When you reset the camera, then send commands, tracking is turned off. You need to restart tracking by calling StartCamera(). Also you can set the camera debug mode by calling SetCameraDebugMode(1) and the commands to/from the camera will be echoed in the terminal window so you can see what it is doing. |
#27
Good Stuff. Thank you.
| Welcome to the WPILib forum | BradAMiller | Programming | 22 | 25-03-2008 22:44 |
| WPILib - Library for robot programming | BradAMiller | Programming | 7 | 21-06-2006 03:12 |
| openFIRST Project Announces Pending Deadline for End of Support for Old Versions | Timothy D. Ginn | FIRST-related Organizations | 0 | 11-07-2005 22:40 |
| Flash Version of Playing Field | Conor Ryan | General Forum | 49 | 30-01-2005 20:08 |
| Does anyone know if we can use the version of Backburner from the 3DSMax trial ver? | lnxpenguin4ever | 3D Animation and Competition | 2 | 26-01-2005 19:58 |
