Go to Post With computers, every once in a while you see something that makes you think "I could have done this, why didn't I think of it? It would have made my life so much easier." Now is one of those times. - Nadav Zingerman [more]
Unread 27-01-2007, 18:04
billdar billdar is offline
FRC #2085
billdar is an unknown quantity at this point
Direct Joystick Access
I'm familiar with the OIToRelay, OIToPWM, and the OIToDOutput functions,
but is there a way to read the state of the joystick pushbuttons directly?
(ie, something like GetTriggerButton())
Basically I'm trying to do some additional logic between when a button
is pressed and when a control action is performed.
Also, a side note. I had to move a couple function prototypes and defines
(but not everything) from API.h into the file I'm calling them from in MPLAB.
I saw an earlier post on this concerning EasyC, but the solution didn't seem
to exactly apply.
Thanks in advance.
-Bill
Team 2085
Unread 27-01-2007, 19:43
divergentdave divergentdave is offline
FRC #1816 (Green Machine)
divergentdave is a jewel in the roughdivergentdave is a jewel in the roughdivergentdave is a jewel in the rough
Send a message via AIM to divergentdave
Re: Direct Joystick Access
Coincidentally, I was struggling with these same problems mere hours ago.
Last things first, you need to define the preprocessor macro _FRC_BOARD via Project->Build Options->Project->C18 tab->Add macro definition. This is because most of the definitions in API.h are inside #ifdefs that check whether it should include VEX or FRC versions of all the functions.
As for the joystick buttons, I believe the function is named GetOIDInput for the buttons and GetOIAInput for joystick axes, so for the trigger button on joystick 1, you would call GetOIDInput(PORT_1, TRIGGER_SW). (disclaimer: this is off the top of my head, I don't have the code in front of me)
Team 1816 - The Green Machine
Unread 27-01-2007, 22:43
FRC #2085
Right on, exactly what I needed. I saw the ifdefs, figured something
behind the scenes set it based on project processor. Thanks for the
heads up on that function.
-Bill
Help! Direct Drive Issues roberthan Motors 16 21-09-2006 09:33
Direct control of a Servo or Speed Controller Schmitty! National Instruments LabVIEW and Data Acquisition 3 06-03-2006 13:53
Direct Control of PWMs and OI in WPILib CyberWolf_22 Programming 7 06-02-2006 19:06
pic: 1097 Direct Drive 01 Anthony Kesich Robot Showcase 16 13-09-2005 22:33
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
