Go to Post Use sensors to collect data about the surrounding environment, then discard it and drive into walls. - Jared Russell [more]
Unread 14-01-2007, 18:28
cprogrammer's Avatar
cprogrammer cprogrammer is offline
FRC #1595 (Gremlins)
cprogrammer will become famous soon enoughcprogrammer will become famous soon enough
Clear Screen
I need to know how to clear the termianl window screen from within MPLAB. ex. printf("blahblahblah\r\n") instead of \r\n i need something to clear the screen, if there is nothing like this please tell me a method of doing this.
Unread 14-01-2007, 19:02
Re: Clear Screen
There is no direct command or special ASCII the IFI Terminal Window will recognize (or at least not the last time I tried the entire ASCII string set), but you can simply send a whole bunch of carriage returns, e.g.,
printf("/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r/r");
Unread 14-01-2007, 19:15
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Clear Screen
You could write your own terminal or use another free one that does have a character that will clear the screen
Unread 14-01-2007, 19:16
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Clear Screen
Get a good terminal emulator, like TeraTerm, and then Google "terminal escape sequence" for the character strings that can be sent to the terminal emulator to create pretty cool user interfaces.
-Kevin
Kevin Watson
http://kevin.org
Unread 27-01-2007, 19:36
brainonska's Avatar
brainonska brainonska is offline
AKA: Magical Steve
FRC #1155 (Sciborgs)
brainonska is an unknown quantity at this point
Send a message via AIM to brainonska
Re: Clear Screen
system("cls");
or...
system("clear");
Real programmers don't comment their code:
it was hard to write... it should be hard to understand
Unread 28-01-2007, 21:48
dwc309 dwc309 is offline
FRC #1552
dwc309 is an unknown quantity at this point
Re: Clear Screen
If you choose Adam 3A terminal emulation and then find a terminal program that supports it, you can have a complete way to control where text is put on the screen.
Unread 28-01-2007, 22:20
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
Re: Clear Screen
Originally Posted by brainonska View Post
system("cls");
or...
system("clear");
I dont think these work on the RC, because these are actually external function calls to the windows terminal, but I may be wrong.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
clear printf box? telefragger2000 Programming 6 05-02-2004 17:40
Can someone clear up please? archiver 2000 1 23-06-2002 22:23
ALL CLEAR archiver 2000 0 23-06-2002 22:19
