Go to Post There are no rules specifically prohibiting the use of cryogenically preserved legumes on the robot. - dtengineering [more]
Unread 27-01-2007, 10:14
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
Moving bot once targeted on the light
Hey, I have this piece of code
if( Get_Tracking_State() == CAMERA_ON_TARGET )
    Switch3_LED = 1;
    pwm10 = pwm08 = 135;
else
    Switch3_LED = 0;
    pwm10 = pwm08 = 127;
Really, it's just the code from the Process_Data_From_Master_uP() in user_routines.c that checks if the camera has targeted the light. pwm10 and pwm08 are the pwms that the wheels are connected to. I was hoping to get very slow movement by setting it to 135.
Once I found that didn't work. I tried controlling a small motor I setup to it that I had earlier controlled with a potentiometer. That to didn't work.
Any reason why this isn't working?
Thanks,
Jedd
Team 1551
Unread 27-01-2007, 11:24
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Moving bot once targeted on the light
Did you try setting the motor to 255? or 0?.. maybe 135 is just to close to neutral
Unread 27-01-2007, 11:26
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Max is right. 135 is still within the deadband of the speed controller. I wouldn't try 255 on the first run, but a little more (say, 150) should definitely be enough to get the robot moving. See this page: http://www.ifirobotics.com/victor-88...r-robots.shtml
The Victor 884 has a deadband with respect to the PWM signal, which is approximately 117 to 137 (127 center). Any PWM signal within the deadband results in no output (neutral).
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 27-01-2007, 11:38
Thanks.I should of mentioned two other things also.
1.) When I tried the motor I had set it to 255. But that didn't anything obviously
2.) When the camera picks up the light, it will slowly (but jumply, and jitterly) tilt upwards. As it does this, the red light blinks, instead of steadily staying on. So I suspect that it only is locked on momentarily to light, not giving enough time change the values of the pwms(?).
Sorry I didn't mention this in the first post.
Unread 27-01-2007, 13:59
Ok, I fixed problem 2! I'm still unsure of how to actually move the robot now though.
Unread 27-01-2007, 19:52
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Is your default_routine() call uncommented? If so, something might be mapped to those PWMs, and you might be getting interference between your code and the mapping in default_routine().
Unread 27-01-2007, 22:46
Nope, it commented out...
Unread 27-01-2007, 23:42
abrockhoff abrockhoff is offline
AKA: Alex Brockhoff
FRC #0011 (MORT)
abrockhoff will become famous soon enough
Send a message via AIM to abrockhoff
make sure that there is no other drive code in that is setting your motors to joystick inputs later on in the code. you would have to comment those out.
just to make sure you realize this code will drive forward until the camera loses sight of the target. just don't want you to smash into anyone. :-D
Unread 29-01-2007, 01:58
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
Question.
This code goes into the user_routines.c file of the workspace. Does this go into the same section where the mapping of the pwm's to the joysticks go? And if so, dont you just fix the problem by setting the pwms from the camera imput, AFTER the pwm mapping of the joysticks? Or is it more complicated than this? We are stuck on this same issue.
TEAM 1706
2007 Judges Award, St. Louis (For our amazing ability to have bad luck)
2005 Rookie Inspiration Award, St. Louis
Unread 29-01-2007, 02:08
ace123's Avatar
ace123 ace123 is offline
AKA: Patrick Horn
FRC #0008 (Paly Robotics - http://robotics.paly.net/)
ace123 has a spectacular aura aboutace123 has a spectacular aura about
Send a message via AIM to ace123
Try something other than 255... I believe 255 is a special value.
Try like 180, which is in the middle, way out of the deadband and not the maximum
Or, you could try 250, and see if the Victor light becomes red
(FYI: The Victor light is the most accurate source if you are stuck with a PWM value problem... that one light tells you a lot of info. If it is flashing orange, it's a 3-pin PWM cable problem, or it's set to a special value that disables it (like if your robot is detached). If it's completely off once you run the code, the motors are running slowly or half-speed. If it's solid orange, they are inside the deadband or completely stopped. If it's bright red or green, it's running full power in forward or reverse.)
-Patrick Horn, Paly Robotics
Check out the space simulator called Vega Strike, modelled after the space simulator games Elite and Wing Commander. It's Open Source too!
If you have ever played Wing Commander, or especially Privateer, and had a feeling of nostalga derived from the you will enjoy these two Vega Strike mods: Privateer Gemini Gold and Privateer Remake!
I'm working on adding multiplayer support this year...
Unread 30-01-2007, 12:33
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
I found that CAMERA_ON_TARGET state goes on and off too much to do any good. I've tried this state and it works realiby:
if( Get_Tracking_State() == SEARCHING)
else
    pwm10 = pwm08 = 135; // 135 is nothing unless its a really geared down motor :)
The SEARCHING state works great and I was able to keep a spike on with relay output.
Amperage Robotics Team 1225
Site under-going revamp. :/
Keepers in Teleoperated mode burkey_turkey Rules/Strategy 47 05-03-2007 12:56
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
How will the Balls Change once FIRST Paints them Mr.G General Forum 28 24-01-2006 23:07
Moving the Nats. Date? roboTICKS-236 General Forum 4 19-03-2003 22:49
ONCE AGAIN, EVERYONE TELL ME THE ANSWER! =) archiver 2001 2 24-06-2002 02:42
