Go to Post FIRST is, of course, a grand social experiment in American culture - jonathan lall [more]
Unread 27-01-2007, 20:52
Back after 4 years off
FRC #5279
Re: Knocking Down Ringers Strategy
Originally Posted by artdutra04 View Post
The only other possible con that this strategy might have is that if one of the tubes falls in front as your robot as it continues to drive, you may be contacting two or more tubes at once as you drive to knock them all down. This would most likely get called by the referees as a penalty for controlling multiple tubes.
You could probably get away with this once but after that you would probably be out of luck.
Also alot of teams will be designing to pick up tubes that are laying down because flat on the ground is the easiest repeatable posistion for all 18 ringers. This may not always be a good strategy.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Knocking down opponents ringers Caseavong Rules/Strategy 6 08-01-2007 17:43
White Paper Discuss: Simple strategy/couter-strategy sheet CD47-Bot Extra Discussion 2 06-04-2004 22:37
Knocking Down The Whole Stack... Suike Regional Competitions 39 30-03-2003 19:33
Image Discuss: Team 60 - Knocking Down Boxes 1 CD47-Bot Extra Discussion 7 12-02-2003 11:05
Knocking Over Boxes oneeightytwo Rules/Strategy 5 10-01-2003 15:23
