Go to Post Part of the magic of FIRST is the interaction between different teams- and that becomes clear as day as the clock starts ticking. - mhayon [more]
Unread 06-01-2007, 19:19
Testament-Doom's Avatar
Testament-Doom Testament-Doom is offline
The wanderer of all worlds.........
AKA: David Perrot
None #0555 (Team 555)
Testament-Doom is a jewel in the roughTestament-Doom is a jewel in the roughTestament-Doom is a jewel in the rough
Send a message via AIM to Testament-Doom Send a message via MSN to Testament-Doom Send a message via Yahoo to Testament-Doom
Post 3DS max help thread
Well, during my time at the kickoff today, I was noting that people had plenty of questions about things in 3DS max, often ones we could answer. Of course we all have questions about anything in robotics, so I thought we could have a help thread in 3DS max.
Some of us out there know a lot about 3ds max and are willing to help others who are in need of answers to problems they run into, so this thread is there for anyone who want to post questions and answers, all user-run, so post anything you need, and hopefully we'll answer these questions.
Testament-Doom's 3D art (If you want to check it out) - http://testament-doom.deviantart.com
"It does not matter how easy or hard it was to create your art, but the end result that matters most." - Me.
Unread 10-01-2007, 19:24
theanimator17 theanimator17 is offline
FRC #1312
theanimator17 is an unknown quantity at this point
Re: 3DS max help thread
Alright. I was wondering how to create water in 3ds max. It seems to be tough. Currently i'd like to make a little lake. If anyone could help me with that, maybe like a tutorial or something, that would be great. thanks in advance.
Unread 10-01-2007, 19:27
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
This thread is where I think you can get the most helpful information as the links will lead to to professionals who have a long history with 3D animation and will give you more than enough assistance.
It helped me and my team through many a nights over the year and I highly reccomend it.
Unread 10-01-2007, 19:28
FRC #1312
um, which one would i go to for water tho?
Unread 10-01-2007, 19:41
AKA: David Perrot
Well, water can be a really tricky thing here. For your case, you just want some type of lake, so particle waters are not what you want, and you don't need to worry much about the physics of water. For some lake kind of water, a plane will do just nicely. The trick is getting the material correct, that is the key here. Water is both reflective and refractive, just to let you know. It's basically transparent but you often see water as blue because of the sky. It's really all about the material in your case, so if you're good with that, work on the material, I gave you some good pointers to help you out. If you need any more help, ask .
Unread 11-01-2007, 14:27
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
here is what I found that works.
Dont use refractive unless your going to show somthing in a the water. The refractive raytrace will jack up your rendering time. Use falloff material for diffuse and opacity. On the diffuse make it so it is light blue in the center and darker on the edge. I know water is clear, but people like to think it is blue.
After add a number of animated wave modifiers to it and it should look like water. You have to do a lot of tweaking to get it to look good. Lighting also plays a big role in the look of the water.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 11-01-2007, 19:54
FRC #1312
Um, ya, i guess that kinda helps. I will post an image or quick video here of my water when i get something. Thanks so far.
Unread 12-01-2007, 00:59
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
alright all venteren animators knows that the DV-NSTC codec kills the quaility of your animation. Is there any program out there that can convert it to that codec without butchering the look of the aniamtion? or which one does the best job? Premire is out of the question, its just awful with DV-NSTC.
A.K.A Llama
Unread 12-01-2007, 07:46
AKA: David Perrot
It's really how you set your codec and stuff. I personally use Camtasia studio for my conversions, it's pretty good. If you want to get it though, it's a 30 day evaluation. Later I'll do a series of tests to see how an animation looks like in different settings using that codec, and I'll get back to you on that.
Unread 19-01-2007, 16:34
Setsanto's Avatar
Setsanto Setsanto is offline
FRC #1334 (OTHS RobOTics)
Team Role: Animator
Setsanto is a jewel in the roughSetsanto is a jewel in the roughSetsanto is a jewel in the rough
Send a message via MSN to Setsanto
Does anyone have any major tips or hints on creating a realistic walk?
2008 : GTA Regional 7th Seed, Quarters
2008 : Waterloo Regional 4th Seed, Quarters
2007 : GTA Regional 2nd Seed, Quarters
2007 : Waterloo Regional Quarters
Unread 19-01-2007, 17:42
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
Well your in luck! I specialize in character animation! Man, I can talk all day about that subject. Well, here it goes.....
First off you must remember that a walk is never the same for each person and also projects their character. For example a woman who is self reserved is going to take smaller and tighter steps. While a big macho man is going to strut his stuff and take wide pounding steps. Also if the character is happy, sad, angry, or drunk their walk is going show it. Happy walk has a lot of bounce in the step, so the torso is going to be moving up and down quite a bit. Sad walk is more dead hardly any moment in the torso and it is slow. Angry walk has arms swinging and feet slamming on the ground as the character stomps around. And drunk walk.....well you get the point.
Now the first thing you want to do is to change your timeline to 24 frames per second. Trust me, it is far easier to think in 24's than it is to think in 30's. Now walks are normally on the dot and do not vary in time when the person is walking. for example, the most common walk is every 2 steps a second. So thats one step for every 12 frames (15 frames if you are animating on 30 fps). mainly here is the break down:
4 frames = a very fast run
6 frames = a run or very fast walk
8 frames = slow run or cartoon walk
12 frames = natural walk
16 frames = strolling walk
20 frames = elderly or tired person
24 frames = slow step
32 frames = I'm....almost.....dead
Now that you know the speed lets take a look at the action. The heel of the foot always leads the toe and the rest of the foot. For example, the heel rises and before the toe does went the foot is about to take the next step. The heel also touches the ground first when the character actually takes the step. Also the toe of the foot stays on the ground until the last moment then the foot swings to a up position barely missing the ground just as the heel hits the ground. Are bodies spend as little energy as they can when walking, so the feet are barely above the ground. That is why it is so easy for us to trip over the slightest crack in the pavement.
So basically it goes like this:
1Heel moves up toe stays on ground (other foot is on step 4)
2foot starts to move forward as toe leaves the ground
3toe swings up as heel makes its way down
4heel touches ground first (other foot should be on step 1 at this time)
5then toe touches ground.
Now you have your feet animated lest talk about the torso.
The torso can do just about anything when the fee are passing each other but when both feet are on the ground the torso is aligned with the feet. Also when the feet are making there pass from the foot in back to the foot in front the torso is up a little higher. So we get this bouncing affect when the character walks. It mostly depends on what mood your character is trying to portray.
Its hard to teach this subject without you being right next to me. The best way to find out how a body moves is to grab a stopwatch and go people watching. Walk behind someone and try to copy there walk and pay attention to where your body is. Most of the time I act out what my character is going to do before I animate them.
Once you completed one cycle of the animation you can just copy the keys so your character's walk is just repeateing. If you do it right, i will look natural.
I hope this helps you and good luck!
A.K.A Llama
Unread 25-01-2007, 23:26
AKA: David Perrot
With that huge list of information about the naturalism of character movement, even I learned something... Thanks a lot!
Unread 27-01-2007, 22:06
Setsanto's Avatar
Team Role: Animator
Thanks alot for the help! I forgot to subscribe to this thread so I almost missed it.
Unread 31-01-2007, 17:35
Theflexmaster Theflexmaster is offline
Alumni of 103 Animation Team
FRC #0103 (Cybersonics)
Team Role: Animator
Theflexmaster is an unknown quantity at this point
You should really try using the mental ray Arch & Design material in 3ds max 9, if you have it. This makes very good looking water just with a plane (animated as well).
Unread 09-02-2007, 01:18
fireball3004's Avatar
fireball3004 fireball3004 is offline
James Davis
AKA: James Davis
FRC #2090 (Punahou Robotics)
Team Role: Animator
fireball3004 is an unknown quantity at this point
Send a message via AIM to fireball3004
I have a stumper for you guys. I am having some problems as I try to render one of my scenes. It is in short of a full mesh with hair walking by a moving camera. I know 3Ds Max is not the happiest programs when it comes to hair, but it's really giving me a rough time. I have tried to render this scene on 5 different computers 15 times total. My Scene is 30 frames long, with basic materials. I would appreciate any help you guys can offer to me, because everyone on my team is stumped.
3ds Max Help! SamC 3D Animation and Competition 12 01-04-2006 20:23
3ds max help reventlov 3D Animation and Competition 7 20-02-2005 00:30
3ds max help reventlov Inventor 0 08-02-2005 17:01
Help with 3ds max CaseyKasem77 3D Animation and Competition 3 07-12-2004 11:05
3ds max 6 help superbeano2004 3D Animation and Competition 6 21-10-2004 20:42
