Go to Post I urge them to build the kitbot and repeateadly smash it into a concrete wall in order to sate their anger. It will soon wane when they manage to do more damage to the wall than to the kitbot. That is honestly the reason that we ended up using the kitframe this year. - Andrew Blair [more]
Unread 17-01-2007, 20:35
Andrewpbhs's Avatar
Andrewpbhs Andrewpbhs is offline
FRC #2023 (PiraTech Engineering)
Andrewpbhs is an unknown quantity at this point
Motor Switches
Hey quick question, can the motor controllers handle 2 CIMS? or do we need one per motor?
Unread 17-01-2007, 20:38
groves groves is offline
Steve Liggett
None #1213 (Groves)
groves is just really nicegroves is just really nicegroves is just really nicegroves is just really nicegroves is just really nice
Re: Motor Switches
One Victor speed controller per cim whether it can handle it or not. thems the rules.
Unread 17-01-2007, 20:42
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Motor Switches
I believe what you describe is legal; however, I know I wouldn't be comfortable with 2 CIMS to a Victor. I'll leave the technical discussion to the other members, but just out of curiosity, why do you want to do such a thing? Victors aren't that heavy, and I believe we received PWM splitter cables in the kit just so that you don't have to modify code to use 2-CIM transmissions...
Good luck
JBot
EDIT: Groves, can you cite me a rule? I see <R91> , but that's the opposite of what you are trying to prove:
<R91> Each motor, actuator, and compressor must be connected to one, and only one, speed controller or relay module.
Aren't signatures a bit outdated?
Unread 17-01-2007, 20:45
Umm Errr...
Re: Motor Switches
Even if the rules allow, i wouldn't do it. Even if the victors could handle it, you would have to power the victor off a single fuse. That single fuse would be constantly blowing and would definately not be able to handle it.
1139 Alumni
Unread 17-01-2007, 21:22
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
Re: Motor Switches
this question came up somewhere else on the forum recently but cant seem to find it
I believe <R91> can and should be interpreted to mean one victor per motor.
in my opinion I would not count a "shared" victor as one victor per rule <R91> technically I would count it as 1/2 victor because it is not devoted to a single motor. that might be stretching it a little but i don't think it is a good idea to attach multiple motors to one victor. when unsure air on the side of caution
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 17-01-2007, 21:31
Hieb Hieb is offline
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
Re: Motor Switches
<QUOTE><R91> Each motor, actuator, and compressor must be connected to one, and only one, speed controller or relay module.</QUOTE>
Your 2 CIMs are 2 motors, thus you would need 2 speed controllers. How many motors you have feeding your transmission is irrelevant.
Unread 18-01-2007, 01:32
dtengineering's Avatar
AKA: Jason Brett
Re: Motor Switches
While you are required to have one Victor per CIM, if you have two CIM motors hooked up to one transmission you may... if you wish... use a PWM "Y" cable to connect both Victor speed controllers to the same PWM output on the robot controller.
Jason
Unread 18-01-2007, 01:50
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Motor Switches
Our team can tell you from experience that they will make you do this. In 2005 we had to reorganize the wiring for four victors because the judges discovered that we were running two CIM's per Victor.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 18-01-2007, 02:18
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer &amp; Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Re: Motor Switches
1 Victor Speed Controller to each Motor. I'm sure FIRST has it this way to save Teams money in having to buy replacements for blown Victors - A victor can only handle so much why stretch the limitation.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 23-01-2007, 13:13
Brian Mocci's Avatar
Brian Mocci Brian Mocci is offline
Still hanging around..
FRC #0195 (Cyber Knights)
Brian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to behold
Send a message via AIM to Brian Mocci
Re: Motor Switches
Although I would never advocate running more than 1 CIM per victor as you would be blowing fuses like its your job, Ruling <R91> does state that it is legal according to its current wording.
In a scenario where there are two CIMS connected to one speed controller, the system would be considered legal as each motor is connected to one, albeit shared, speed controller. However, if the rule was written (Or interpreted) backwards, as one speed controller per motor this would be illegal.
Please correct me if I'm wrong here
UTC Regional Champions
2006
UTC Innovation And Control Award
Nationals Innovation and Control Award
Nationals Einstein Runner-Up
Unread 23-01-2007, 14:31
Re: Motor Switches
Just in case someone thinks this is still a good idea, the FETs in the speed controllers are good for 65 amps each. Times three, that is 195 amps on a good day at room temp. A Chalupa has a stall current of 129 amps so two would be 258 amps, more than 60 amps over max for the FETs. Goodbye little Victor! That is why the rule is written to use only one motor per Victor so there is no smoke obscurring views at events.
Unread 23-01-2007, 14:35
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Motor Switches
I think you mean inspectors.
Unread 27-01-2007, 22:26
Jared Russell's Avatar
Taking a year (mostly) off
Re: Motor Switches
Mmm...chalupas.
Switches CronosPrime1 Electrical 6 26-01-2006 18:22
Switches... Code\\Pilot Programming 13 16-02-2004 13:23
Limit switches Team168 Programming 8 10-02-2003 16:22
switches in order PBoss Programming 5 26-01-2003 22:02
Reed switches archiver 2000 4 23-06-2002 22:08
