Go to Post I think that's what they think you will think, therefore you are thinking what they want you to think. - Wetzel [more]
Unread 27-01-2007, 22:33
imax48236's Avatar
imax48236 imax48236 is offline
El Presidente
AKA: The Elf
FRC #1701 (Robocubs)
imax48236 will become famous soon enough
Send a message via AIM to imax48236
pic: Team 1701 Electronics Board
Unread 27-01-2007, 22:41
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Re: pic: Team 1701 Electronics Board
Wow 8 - 40 AMP Breakers / Motors!! I can watch the battery power drop already. . . 4 Spikes also . . . .
Some nice wiring for that may motors/spikes. . . . Not sure if I want to see the Operator Control board or Software to control them all. Nice Job
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 27-01-2007, 22:43
Syncopation's Avatar
Syncopation Syncopation is offline
I can't make a dongle outta 25-pin!
FRC #0932 (Memorial Circuit Chargers)
Syncopation has a spectacular aura aboutSyncopation has a spectacular aura aboutSyncopation has a spectacular aura about
Send a message via ICQ to Syncopation Send a message via AIM to Syncopation Send a message via MSN to Syncopation Send a message via Yahoo to Syncopation
Nice bundling. I'm still not used to the new yellow backup battery, though.
I'm agreeing with Gamer930... keep those batteries charged!
Team 932:
2008 Oklahoma City Xerox Creativity Award
2008 Oklahoma City Autodesk Visualization Award
2008 St. Louis Chairman's Award winner
Home of the 2008 St. Louis Woodie Flowers mentor
2007 Kansas City Engineering Inspiration winner
2006 Lone Star Regional Finalist alliance member
A mathmatician, a physicist, and an engineer were all given a red rubber ball and told to find the volume.
The mathmatician carefully measured the diameter and evaluated a triple integral.
The physicist filled a beaker with water, put the ball in the water, and measured the total displacement.
The engineer looked up the model and serial numbers in his red-rubber-ball table.
Unread 27-01-2007, 22:54
matthewsh matthewsh is offline
FRC #1421 (Team Chaos)
Team Role: Electrical
matthewsh is an unknown quantity at this point
Nice job! Very clean. One thing though, you need to hook up both maxi circuit breaker panels to the power distribution block separately.
<R57>
All circuit breaker distribution panels must be connected directly to the power distribution block. No intermediate connections are permitted.
Other than that it looks great.
Matthew
Unread 27-01-2007, 23:52
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
I'm not sure of your application for 8 Victors, but you can hook the Victors up to the black fuse panel. I would recommend this for weight and simplicity reasons, but I'm not sure of the motors you will be attaching. I agree with Matthew, you must hook the other fuse panel to the power distribution block, it is clearly stated in the rules.
Ryan
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 28-01-2007, 00:49
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Please, please replace that poor 12 gauge wire going from the 120A breaker to the power distribution block with a 6 gauge wire appropriate for the load. Otherwise its bound to go up in smoke once you get a few of those vics pulling amps - and that wouldn't be pretty!
And run a separate lead for the second maxi, as previously noted.
Other than that, it looks good - nice and compact and fairly tidy wire bundles
EDIT: Actually, I think based on <R57> you may need 6 gauge wire from the power distribution block to each of your breakers as well. I'm not an electronics guy though, so someone should check me on that. I couldn't find anything stating that you MUST have 6 AWG there, but the 7th bullet of that rule suggests such.
- Jeff
Unread 28-01-2007, 02:45
ZackCraig's Avatar
ZackCraig ZackCraig is offline
The Walking CPU
FRC #1856 (GEARHEADS)
Team Role: Webmaster
ZackCraig will become famous soon enough
Looks... Simple, which is good for swift accurate repairs and managing
Unread 29-01-2007, 15:41
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
only CIM motors use 40A and you can only have 4 2.5in and 2 3in CIM motors, for those of you that don't know math thats 6 motors not 8
Jason
Unread 29-01-2007, 15:54
K.Porter's Avatar
K.Porter K.Porter is offline
Not So Random!
FRC #0172 (FALGOR)
K.Porter will become famous soon enough
Send a message via AIM to K.Porter Send a message via MSN to K.Porter
Yes, as has been stated previously: #6 awg, please!
That 12 gauge will go up in smoke if you actually run all the victors in that configuration.
You may also want to plan on switching some of the leads to the Victors over to the other breaker panel. Many of the motors you may use only draw 20 or 30 amps, and those breakers won't fit in the 40 amp maxi blocks you have now.
Unread 29-01-2007, 16:24
in between teams
AKA: Luke Van Oort
This is incorrect. The Fisher Price motor pulls enough current that they could warrant the use of a 40A breaker, however they will be prone to letting out their magic smoke if run near that. 4 CIMs + 2 FPCIMS + 2 FP = 8.
Team 1219: 2009 - Mentor
Unread 29-01-2007, 20:18
imax48236's Avatar
El Presidente
AKA: The Elf
Lightbulb Re: pic: Team 1701 Electronics Board
Thanks for the suggestions, we have fixed the guages from the distribution block and from the main breaker.
2007 Events:
Great Lakes Regional
Detroit Regional
<THIS SPACE FOR RENT, $3000 donation to Team 1701>
pic: Team 188 Electronics Board (Bottom) Mr. Lim Extra Discussion 7 02-02-2009 16:52
pic: Team 1712's 2007 Electronics Board Chuck Glick Extra Discussion 13 31-01-2008 07:07
pic: Team 1701 Electronics imax48236 Robot Showcase 5 20-02-2006 23:09
pic: TEAM 1636 Electronics Board LightWaves1636 Extra Discussion 1 14-02-2006 19:08
pic: 701 Electronics Board Doug G Robot Showcase 19 13-02-2006 19:40
