Go to Post I think we're doing pretty well . . . but I will never, ever say that "we are ahead of schedule." It's a curse. :D - Éowyn [more]
Unread 27-01-2007, 22:45
cdfps cdfps is offline
AKA: Ross Kowalski
FRC #0348 (Norwell Robotics)
cdfps is an unknown quantity at this point
Re: Banebot Transmission Issues
We put both banebot transmissions on a little test platform robot (20lbs?) that we were using for coding while the robot was being built.
We were getting some strange behavior with one of the transmissions where it would periodically develop a tight spot. We ran in the transmission with an old CIM for about 10min with a battery and no load. No difference. We disassembled it and flushed it. There were little silver metal chips in the flushing.
We then ran it in backwards with a dewalt drill on the output shaft for a few minutes with no load and mineral spirits for a lubricant. After this, we flushed it again and blew it out lubed and reassembled it. It ran fine after this.
If you do decide to flush it, remember that the solvent will get into the output shaft bearings.
small banebot motor with 64:1 gearbox burkey_turkey Motors 16 29-01-2007 01:48
BaneBot Transmission Encoder Daru Motors 9 27-01-2007 23:17
Banebot 2 motor adapter Ben Piecuch Motors 5 17-01-2007 16:06
Banebot 64 to 1 on Spike? falconmaster Motors 7 15-01-2007 22:12
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
