Go to Post the whole process is the most valuable part, not the award itself - Rich Kressly [more]
Unread 27-01-2007, 23:09
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
cmu cam pwms
hi im using kevin's "bells and whistles" version 2.1
does any one know the pwm outputs for the pan and tilt,
and one more question where do i get power to the camera, i think its through pwm, if it is which pwm do i plug it in to
Unread 27-01-2007, 23:19
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: cmu cam pwms
By default, pan is PWM01, and tilt is PWM02. The power for the camera does come from the PWMs... you can put it on any one you aren't using.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 27-01-2007, 23:21
seanl's Avatar
Re: cmu cam pwms
alright cool thanks.
Unread 29-01-2007, 11:49
jdejoannis jdejoannis is offline
FRC #1845
jdejoannis will become famous soon enoughjdejoannis will become famous soon enough
Re: cmu cam pwms
The wiring is explained in the CMUCam2 Workbook under Section 5 for MPLAB. For EasyC, I understand that the PWM's may be different.
CMU cam Booger Programming 3 18-07-2006 00:00
CMU Cam on an EDU-RC Redneck Programming 2 11-02-2006 14:55
CMU-Cam power QuantumNinja Programming 1 01-02-2006 21:14
CMU CAM setup stephenthe1 Programming 0 17-01-2006 11:36
CMU Cam GUI Arc736UV Programming 2 15-03-2005 19:26
