Go to Post Every game design should be a means to an end. - Mark McLeod [more]
Unread 27-01-2007, 15:47
customh customh is offline
AKA: Travis
FRC #2241 (SWAT)
Team Role: Electrical
customh is an unknown quantity at this point
Send a message via AIM to customh Send a message via MSN to customh Send a message via Yahoo to customh
Signal light trouble-shooting
We have wired the signal light as appropriately as possible, but there is not voltage going through the red wire to terminal 5 on the solid state relay.
If anyone could help that would be great!
S.W.A.T. Team 2241
Coon Rapids High School
Unread 27-01-2007, 16:32
robbrad robbrad is offline
FRC #1875 (Autonomato Autonomatons)
robbrad is an unknown quantity at this point
Re: Signal light trouble-shooting
First check your circuit. It the breaker closed? Is their a good fuse/breaker in the panel? If that checks out, use a multimeter to test for resistance between pins 5 and 1. This would tell you if the problem is internal. Mine has about 190k Ohms of resistance. Post your results.
Unread 27-01-2007, 22:23
AKA: Travis
FRC #2241 (SWAT)
Well the issue isn't the breaker because we have the relay DIN-mounted and everything else running on PWM is getting power, and as far as we know (by the "Guidelines, Tips, and Good Practices" sheets) it is supposed to run off of a PWM. We have wired it per that and it does nothing.
Unread 27-01-2007, 23:17
matthewsh matthewsh is offline
FRC #1421 (Team Chaos)
matthewsh is an unknown quantity at this point
Where do you have the PWM cable connected on your RC? It is supposed to connect to one of the team color connectors. I'm thinking that you might have connected it to the PWM connector on the RC. They updated the wiring diagram to show where it connects. You probably don't have the new version. Get it here...
http://www2.usfirst.org/2007comp/oth...L_LIGHT_R1.pdf
Matthew
Unread 27-01-2007, 23:27
AKA: Travis
FRC #2241 (SWAT)
Nope, we have it in one of the Team Color ports. Also I checked that schematic, and that is exactly what we were wiring it per earlier today. Its like our team color ports are hosed.
Unread 27-01-2007, 23:30
Has the light lit up at all? Did you try connecting the light directly to a battery to check that it works?
EDIT: Nevermind. I understand better now. It sounds like something is wrong on the RC end. I'm thinking...
Unread 27-01-2007, 23:38
AKA: Travis
FRC #2241 (SWAT)
I was thinking RC too, but we have had no other issues. We should have tried the light on straight power though, it is a very likely component to fail compared to other things. Have to check that on Monday, meanwhile, any other ideas?
Unread 28-01-2007, 00:02
Tell me if you agree on the following:
The white wire is power (+)
The red wire is the trigger for the relay
The black wire is ground (-)
Thats what I think is going on. I'm not sure what the individual pins for team color on the RC are. IFI does not reveal that in any of their documents.
We do know, however, that last year (and I assume this year) the channel you were on determined the color the diagnostic light would be. Either red or blue. Red is default. To get blue you had to be on channel 13 or 31. Perhaps you accidentally changed the channel? Thats one thing to check, although I think that is unlikely because I vaguely remember that you had to do something weird in order to change the channel. Hope that helps. I will try do some testing Monday.
Unread 29-01-2007, 19:32
AKA: Travis
FRC #2241 (SWAT)
Apparently we tried the light and that works, and we have it wired right, other ideas?
Unread 29-01-2007, 20:52
Did you check to see that you are on channel 40? If so, try loading to latest version of the default code. I don't think anything in the user changeable code can control how those team color ports behave, but it is worth trying. Also, try connecting one of the old team color lights (that change from red to blue) and see if it lights up. If it does not light up, contact IFI. Let us know how it goes.
Unread 29-01-2007, 21:08
Are you on a rookie team? If so you obviously will not have an old team color light.
Take some pictures of what you have wired (get different angles of it) and upload them here.
Also, have you successfully ran your robot any? Does the RC work as it should other than the signal light problem?
Unread 31-01-2007, 06:50
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
MSB for the team number on the OI has to be changed to "1 / ON" indicating a high team number (off the top of my head, I don't know what it is, but I believe it is in the 3000's) Then you have to change the channel DIP switches on the OI into a specific sequence for the various channels. THEN you have to tether the RC to the OI and let it resync the team number. Finally, after all that you will be running on the secondary channels.
As for the red vs blue, I have a feeling that IFI changed the master code to reflect the new indicator. Keep in mind, at competition you have a 50% chance of getting on a blue channel.
As for getting your light to work, check that the relay is working correctly, and check your PWM cable (they DO fail). If you have a steady hand, you could use a voltmeter on the Team color pins and confirm that your RC is putting power to those ports.
If you know any teams around you, try contacting them and seeing if they have spare LED block from a previous year that you could borrow and confirm your RC is ok.
Having someone else double check your wiring and cable termination is also a good suggestion; not everything goes as planned when you're working late at night and mistakes do happen.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 31-01-2007, 08:23
I am sure you have checked this but the Team LED jacks have five pins. Following the Tips and Guidelines be sure that "The PWM cable then plugs into one of the four Team Light 5–pin jacks on the RC with the Black wire on the Blk pin. Any excess PWM cabling needs to be secured into a harness and anchored to the chassis." The pins are extremely small and it's easy to be one pin off.
Another possibility is the solid state relay connections are touchy and it is easy to insert a wire so that the insulation is actually under the clamp when you tighten the hardware or the wire may have missed the connection altogether. Try removing the wires and reattaching both input and output. Without the LED attached you should be able to use a voltmeter to look at the output side of the relay and see +5 volts.
Unread 02-02-2007, 10:32
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Al, my crew has tried all this and we still can't get the light to work. I'm not sure if we did the voltmeter check correctly, but we did get a value of +5 once. We also connected the light directly to the battery to make sure the light works and it does. Also, the little rectangular red light on the allen-bradey solid state relay has never gone on - is it supposed to? Also, given the schematic, position 2 (12) is currently unused. Is that correct?
I'm down to bad pwm or relay???? thoughts?
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 02-02-2007, 10:56
Rich,
We haven't installed out relay yet so I am guessing on this. The installation in the Tips and Guidelines isn't clear on this but you need to provide a jumper between pin 1 and 4 for the LED to get a return line. The LED on the relay should light when the relay is getting a command. The relay is sensitive to polarity but I am guessing you have followed the schematic to the letter on color code. You should be able to get the light on the relay to turn on and off without having the big LED even connected. According to the RC manual, the Team Color outputs are circuit breaker protected internal to the RC It is possible that you have a defective circuit breaker. I would try to connect to last year's RC and see if you can get it to work. Using a voltmeter measure between pins 1 and 5 on the relay socket and you should see 5 volts when powered on. If not check carefully the pins on the team color connectors on the RC. If you have 5 volts between red and black then you have a bad PWM cable. Let me know what you find.
Green light same color as overhead light Ethulin Programming 13 02-08-2007 15:24
Whats the Robot Signal light for? steve d Electrical 12 20-02-2007 08:29
Multiple Light Tracking with Distinct Light Boxes MaHaGoN Programming 30 19-02-2007 10:46
Inventor software trouble/ FIRST Base trouble nasa-senpai General Forum 2 24-01-2007 09:15
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
