Go to Post This tee-shirt collecting gets kind of addicting, doesn't it? - Chief Hedgehog [more]
Unread 27-01-2007, 01:38
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
pic: Need a place to park a robot?
Unread 27-01-2007, 01:39
Nate Edwards Nate Edwards is offline
SWARM Head Mentor
FRC #0957 (SWARM)
Nate Edwards will become famous soon enough
Re: pic: Need a place to park a robot?
It looks mighty big, do you have to park sideways in the homezone? I imagine you don't have to lift anything. How do you knock the ramps down? What angle is the ramp? Looks good
South West Albany Robot Mechanics
2002 Pacific NW Regional Rookie All Star Award Winners
2003 Pacific NW Regional Daimler Chrysler Team Spirit Award Winners
2004 Pacific NW Regional Johnson & Johnson Sportsmanship Award Winners
2004 Pacific NW Regional Winning Alliance (492 (#1 Seed), 1031, 957)
2003 & 2005 Pacific NW Regional Chairman's Award Winners
2009 Oregon Regional Woodie Flowers Award Winner
Unread 27-01-2007, 02:02
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Hi Nate, The ramps deploy off the sides of the bot so we just need to drive it straight into the home zone. Our alliance partners have to approach it runing parallel to the end wall however, so positioning is critical. We're also worry about what effect tubes laying on the carpet may have. The ramps are deployed by a 64:1 banebots gearmotor turning a lead screw that drives them over center. The ramps then free fall to the carpet. The impact is cushioned by a pool noodle on the big ramp and 1/2 inch dense foam on the smaller one. We've done drop test on the ramps and so far so good. The ramp angle is 20 deg. The 12 inch high parking area is 76 x 37 inches.
Unread 27-01-2007, 02:37
SWARM Head Mentor
FRC #0957 (SWARM)
That answers my questions, I think it is going to take more time to have robots go parallel, but the robots can be fairly close with this design when going up.
Unread 27-01-2007, 10:17
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Is that a diamond plate platform, if it is, you might want to put some clear paint on it and sprinkle it with sand, remembering from last year, the ramp was pretty slick.
good luck
malhon
Unread 27-01-2007, 13:56
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
It looks nice but a bit heavy. How much does it weigh?
Unread 27-01-2007, 15:36
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
It weighs 75 LB without the electronics....Looks can be deceiving
The diamond plate has pretty good traction. We may sandblast the area where the wheels will ride depending on how our tests come out.
Unread 27-01-2007, 22:36
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
how exactly did you hook up your lead screw to deploy your ramps? Does the nut actually come off the end of the lead screw? (which would mean that you couldn't bring your ramps back up, but that's probably okay)
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 28-01-2007, 00:24
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Hi Richard, Yes, the nut actually comes off the screw. The nut travels 28 cm from down on the screw til it comes off. That takes less than 5 seconds. Once clear of the screw the now over centered ramp free falls to the carpet. We have installed a bolt and wing nut to hold the ramps in the retracted position while we exit the field following the match. Once back in the pits we'll rethread the nut and be ready to go again.
Unread 28-01-2007, 16:23
imax48236's Avatar
imax48236 imax48236 is offline
El Presidente
AKA: The Elf
FRC #1701 (Robocubs)
imax48236 will become famous soon enough
Send a message via AIM to imax48236
My concern comes from the gap in the middle of the top platform. If an approaching robot is not of the traditional chassis shape, it is possible that the other robot could fall into the hole.
Our robot is 3WD, with a center wheel in the back. It looks to me like we would fall into that hole.
Are you planning on covering that hole with plexi/Lexan?
2007 Events:
Great Lakes Regional
Detroit Regional
<THIS SPACE FOR RENT, $3000 donation to Team 1701>
pic: This is our robot as of last night. Alot more should get done this week now that things are in place dfukuba Extra Discussion 28 25-01-2007 13:14
pic: Evil Machine 4 Goes for a Walk in the Park Kristian Calhoun Extra Discussion 9 23-08-2006 03:26
pic: It's great making new friends at the park! Koko Ed Chit-Chat 29 20-07-2006 04:35
pic: Place your bets Tytus Gerrish Extra Discussion 20 23-08-2005 15:49
pic: Party Park CD47-Bot Extra Discussion 4 19-04-2004 18:26
