Go to Post Kickoff features the joys of discovery. Ship date features the fear of utter failure. - Koko Ed [more]
Unread 27-01-2007, 10:45
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Problem with TTL-RS232 + CMUCam
For whatever reason, I cannot get the PIC18 to communicate with the camera via the TTL port (shifted to RS-232 of course). I'm 99.9% certain the wiring is correct, and we have 2 level shifters (hopefully both aren't fried) to test with. I'm currently using Kevin's serial port functions and I cannot send or receive anything to/from the camera.
I've even tried loading Kevin's bells and whistles camera program, and that refuses to do anything either (in minicom it just says it is waiting for data). There is no issue communicating with the camera via the DB9 port to the computer (using either minicom or the GUI), so I'm really confused as to what's wrong.
Do I need to set a jumper to enable the 3-pin RS-232 port on the camera, are both level shifters gone, or am I just an idiot (what I'm hoping, we don't really need hardware failure right now)?
Thanks in advance.
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 27-01-2007, 11:51
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Problem with TTL-RS232 + CMUCam
Thanks in advance.
Is the baud rate correct?
Nothing attached to the DB9?
Are the camera LED(s) on?
Did to try the serial port diagnostics code?
Consulted the FAQ?
-Kevin
Kevin Watson
http://kevin.org
Unread 27-01-2007, 20:28
Do I need to set a jumper to enable the 3-pin RS-232 port on the camera,...?
No, but you do have to remove anything that might be connected to the DB9 connector.
Unread 28-01-2007, 00:19
AKA: Harry Bock
FRC #1350 (Rambots)
Okay, thanks for the help, I figured it out. For whatever reason, I guess setting stdout_serial_port to whatever the camera was communicating was mangling the commands I sent to it. Once I reset that to the program port and just starting writing buffers with the byte-oriented functions it worked flawlessly.
Thanks again for the help
Unread 28-01-2007, 00:57
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
What do you mean by "reset the program port and writing buffers with byte-oriented functions" ?
Unread 28-01-2007, 01:11
AKA: Harry Bock
FRC #1350 (Rambots)
Sorry, it's late, I don't make much sense past 1 AM.
I mean, I set stdout_serial_port = SERIAL_PORT_ONE and instead wrote a simple function to take a C-style string and write it to the TTL port one byte at a time. i.e.
void cmucam_write_buf(const rom unsigned char *buf)
    int i;
    for(i = 0; i < strlen(buf); i++)
        cmucam_write( buf[i] );
cmucam_write_buf("tc 210 240 210 240 210 240\r");
Unread 28-01-2007, 08:47
AKA: Nir Levanon
Why do we use a TTL -> RS232 converter for the CMUcam? JBotAlan Programming 6 29-11-2006 13:54
CMUCam TTL problems gabrielse Programming 4 13-02-2006 14:07
EDU-RC, USART2 (TTL), CMUCAM ChrisHomer44 Programming 2 30-04-2004 21:38
laser radar with BS2p using RS232 problems... chei_UCF19 Programming 6 26-02-2004 15:21
Having trouble with TTL port Gene F Programming 12 10-02-2004 15:23
