Re: Banebot Transmission Issues
We were moving a load of about 5 foot-pounds of torque, while shockloading by changing directions. So, I would call this a small to moderate load. Also, our solution of welding the shaft to the plate has failed twice, we've re-welded it a third time. Since each piece is a different type of steel, it's just not working well. Also, you have to weld with the bearings in place and you're restricted to welding from one side. In synopsis, these gearboxes are less than suitable. That's Karthik putting it mildly. |
We assembled one of our Dual CIM kits today. As stated in the instructions, the key will need to be filed down to fit further back in the key slot for everything to fit together right. We put a wheel on the shaft and backdrove it. It feels nice. The motors haven't been run yet. Will update once we do. As a note, the dual motor kit adds only about 1/16" to the overall length of the gearbox assembly.
Mid way thru the build is no time to be finding this out. If we bench tested every component, we'd still be three weeks into the build, with nothing designed. We go into this knowing it's about teaching engineering problem solving; but it should not be about solving the supplier's engineering problems. I want to know if they plan on paying for our services! Happy low scoring everyone! |
The quick reversing of direction can be avoided with careful programming and control setup, and I have a feeling that this is much more likely the cause of the problem than the 5 ft lbs of torque.
It sure is nice to have this early failure report, so we know to be careful with the BB gearmotors, and have contingency plans in mind using either the Globe or window motors. |
Karthik,
Thanks for backing up our hesitation to use these gearboxes. It seems like everyone who's used these things before thinks they are garbage.. |
Is there any easy way to avoid this problem?
Such as supporting the drive shaft on both sides? I already knew that sideloads are never good for planetary gearboxes, but could they really ruin them like this? |
#7
I have done some calculations, some FEA's and finally this past week some tests. I am still working on my "final report" but here is my initial report. The joint fails under static loading when the input to the 12:1 gearbox is about 3X the 12V stall torque of the CIM motor. The joint fails under back and forth cycling at about 2X CIMstall. From my point of view, the joint as shipped is not strong enough to be used with the 2 CIM adaptor from BB. It seems like it should be okay for use with 1 CIM with the 12:1 ratio but I am not sure because I usually estimate the dynamic loading to be twice the static loading. That would make the 12:1 gearbox right on the edge of acceptable. BUT, in this case, with teams rapidly switching from forward to reverse, I am not sure that a factor of 2X is enough. The 56mm carrier plates are pretty soft. They are Rockwell A hardness of about 46 -- corresponding to a yield stress of about 64,000psi. It is not too hard to get a material with a yield stress of about 2-3X that number. I think that that is probably where I am going to go with my recommendation. More to come. Joe J. *In many ways, double D's are not very effective torque transmitters, they cause stress risers and concentrate stresses on small sections of the joint. Splines are better because the distribute the stress to more material but not as easy to make. |
#8
Thanks for the analysis....I was referring to applications for the small Banbots gearmotors, not the 56mm version. Manipulators can be set up to have gradual acceleration, there should not be much requirement for quick back-and-forth motion, hopefully.
I agree that in driving applications the back-and-forth motion is pretty much unavoidable, so your single CIM per transmission recommendation makes good sense. |
#9
We were going to use a FP with a BB 42mm, 256:1 mated by chain with an additional 6:1 reduction to lift our arm (less than 3 lbs.)...our prototype has worked well but??? Would addition of gas spring reduce some of the shock and help us reduce our concern over these BB's...or should we start over?
#10
we were planning on 8:1 chain with a 64:1 or 128:1 BB gearbox, and either the BB motor or the weak Mabuchi motor. Arm weight is similar to yours. We are planning on using a gas spring to take most of the weight of the arm.....and we are also planning on being able to start over and put a window motor or two on it to replace the gas spring and BB stuff if it doesn't work out.
#11
Now you just had to scare me Karthik... We ordered a pair of these early last week and have yet to receive them. With our troubles last year of using the FP in the 36mm gearbox's made for only a RS-385 motor under a low load application, I should have expected this. I was hoping these larger gearbox's would be able to handle the power of a FP motor. We will do some testing when we get ours in and see what we come up with... but now I am scared of these gearbox's...
#12
I am not saying teams should panic. I believe the BB transmissions are still a great bit of engineering. BUT, like all things they have limits.
I believe that the higher ratios are even useful, but more for speed reduction not torque increase. The output joint is the same for every ratio. If the torque gets too high it will break that joint. Now to your questions: Will a gas strut or other counter balance help? Yes it can but it is not a panacea. Counter balance is just flat out a good idea. Teams should do that regardless of what motors they choose. Should you toss out the BB design and start over with a window motor? This is a tough question. The window motors are great motors too but they only have about 20W of power available. If you are doing some significant work with the motor, you will have to do it about 1/5 as fast with a window motor than with a BB motor. If you are using the higher ratio but you never stall the motor you are probably going to be just fine (try to limit impact loading if you can). In rough numbers, I project that the 42mm gearbox will fail with repeated cycling loads of +/-350in-lbs. I project that the 36mm gearbox will fail with repeated cycling loads of +/-100in-lbs. If you can design your mechanism to keep your loads below these (with a safety margin that lets you sleep at night), then I think you should be okay. Joe J. |
#13
Thanks again, you have pretty much mirrored my thoughts.
#14
Thanks for the warnings everyone. We have an FP motor with 42mm, 256:1 BB gearbox installed on our arm and an additional 7.2:1 chain reduction. So far, there have been no problems, but we are definitely going to look at the internals tomorrow.
I think many people have said it already: impulsive loading is the killer. One thing I can think of that might make a big difference: chain backlash. If on a direction reversal, your mechanism has significant momentum before the chain engages, the stresses will be enormous. Preloading your mechanism so that the chain is always in tension is always a good idea, but in light of the new gearbox info I think it will be even more important. |
#15
Boy am I glad that we chose to use four KOP trannies instead of two with our 4 CIMs in the drivetrain. We also ran in each motor/trans combination without load for a few hours - they definitely loosened up after that and drew nearly half the current of when we first started.
Our design is such that a change now would be nearly impossible, so we're going with the KOP trannies - but we might just disassemble them, clean them out and refresh the grease. The small 64:1 trans will be sued for a light load, but we ran that in as well. Counterbalance was not somehting we considered, but in retrospect it should've been obvious - thanks Joe J for reminding us. Don |
| small banebot motor with 64:1 gearbox | burkey_turkey | Motors | 16 | 29-01-2007 01:48 |
| BaneBot Transmission Encoder | Daru | Motors | 9 | 27-01-2007 23:17 |
| Banebot 2 motor adapter | Ben Piecuch | Motors | 5 | 17-01-2007 16:06 |
| Banebot 64 to 1 on Spike? | falconmaster | Motors | 7 | 15-01-2007 22:12 |
| Banebot Gearbox | chris31 | Technical Discussion | 45 | 15-01-2007 17:56 |
