Go to Post Some of us should be so lucky to have something go wrong on Einstein. - Kevin Sevcik [more]
Unread 28-01-2007, 01:05
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
TTL Issues
We've been told by a 3rd year team in our country that they had a problem with thier CMU cam last year and they figured out it was because of the TTL, because it was loose one the pins it was connected to(on the RC). Before we attempt to weld it or hot glue, is sticking it properly to the RC the right thing to do?
Unread 28-01-2007, 01:07
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: TTL Issues
It helps immensely, but only if it's already making proper contact. The idea is to check to make sure it's working, then hot glue it into place. The main problem is simply that it wiggles loose from vibration and simple working on the wries near it. Hot gluing the adapter just helps keep it in place.
Unread 28-01-2007, 10:13
AKA: Nir Levanon
Re: TTL Issues
Oh, wow! That's really important you told me this
beacause it doesn't work!
Unread 31-01-2007, 07:31
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: TTL Issues
All the PWM wires to and from the camera seem to fall out. We're going to make sure we tie down everything when we're actually in competition.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 31-01-2007, 09:23
Re: TTL Issues
The sides of the camera frame have slots that seem designed for fastening pwm cables to.
CMUCam TTL problems gabrielse Programming 4 13-02-2006 14:07
TTL port diognostics railerobotics Programming 0 16-01-2006 10:46
RS-232 TTL Board? Sidney San Martín Electrical 8 08-01-2005 22:46
TTL Ports bludstayne Programming 3 02-03-2004 16:41
TTL pins Dave... Control System 3 07-02-2004 23:59
