Go to Post Eription- the condition of shredding the eardrum from excessive cheering at robot competitions - Wayne C. [more]
Unread 28-01-2007, 01:07
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: TTL Issues
It helps immensely, but only if it's already making proper contact. The idea is to check to make sure it's working, then hot glue it into place. The main problem is simply that it wiggles loose from vibration and simple working on the wries near it. Hot gluing the adapter just helps keep it in place.
CMUCam TTL problems gabrielse Programming 4 13-02-2006 14:07
TTL port diognostics railerobotics Programming 0 16-01-2006 10:46
RS-232 TTL Board? Sidney San Martín Electrical 8 08-01-2005 22:46
TTL Ports bludstayne Programming 3 02-03-2004 16:41
TTL pins Dave... Control System 3 07-02-2004 23:59
