Go to Post COMPETE like crazy for the 2 minutes you are on the field, COOPERATE like crazy all the rest of the time. When we play this way, we all win. - Chris Fultz [more]
Unread 28-01-2007, 11:48
daviamp daviamp is offline
FRC #1254
daviamp will become famous soon enough
Question 24 Tooth Gear Sprocket
Our team is using the two 24 tooth sprockets supplied in the KOP, our question is can we use those for the front wheels and purchase and use on the robot two more from Innovation First? We are having trouble interpreting Update #6 Section #10.
Thank You,
David Lamp
Team #1254 Entropy
Unread 28-01-2007, 11:56
Billfred's Avatar
Billfred Billfred is offline
Re: 24 Tooth Gear Sprocket
Team Update #6 basically says you can't use more than two of the KOP 24-tooth sprockets since they were custom-fabricated for the Kit of Parts. Getting more 24-tooth sprockets from IFI (or anywhere else that meets the definition of a VENDOR in the manual) is absolutely fine.
Unread 28-01-2007, 11:57
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
You may purchase 24-tooth sprockets from IFI. However, keep in mind that they are not identical to the ones that came in the KOP. Specifically, they are aluminum instead of steel, and they don't have that raised spacer ring on one side.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 28-01-2007, 12:39
Billfred's Avatar
...however, they do include spacers (aluminum, I think) that serve the same function.
Unread 29-01-2007, 00:04
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
The KOP sprockets have a spacer ring actually machined into the sprocket body itself, and are made of steel. The IFI sprockets are aluminum, but have to same bolt pattern. They come with spacers, but I opted to use my own for a shortened chain "jut-out-ness" and to get a tighter fit with 8-32 screws, I didn't want't to tap out the hub for the 10-32 screws that were supplied.
IMO FIRST kinda slipped on this one. The 24t sprockets are impossible to find, and the 15t sprockets don't even have a set screw on them....
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
[OCCRA]: Trade for 45-Tooth Sprocket (x2) Silent_Stryker OCCRA 0 27-09-2006 13:25
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Gear Tooth Sensors et1337 Electrical 7 28-01-2006 22:48
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
Gear/Sprocket Help Joseph F Motors 3 18-03-2002 07:48
