Go to Post Water game. - dlavery [more]
Unread 28-01-2007, 12:39
Billfred's Avatar
Billfred Billfred is offline
Re: 24 Tooth Gear Sprocket
Originally Posted by jgannon View Post
You may purchase 24-tooth sprockets from IFI. However, keep in mind that they are not identical to the ones that came in the KOP. Specifically, they are aluminum instead of steel, and they don't have that raised spacer ring on one side.
...however, they do include spacers (aluminum, I think) that serve the same function.
Unread 29-01-2007, 00:04
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
The KOP sprockets have a spacer ring actually machined into the sprocket body itself, and are made of steel. The IFI sprockets are aluminum, but have to same bolt pattern. They come with spacers, but I opted to use my own for a shortened chain "jut-out-ness" and to get a tighter fit with 8-32 screws, I didn't want't to tap out the hub for the 10-32 screws that were supplied.
IMO FIRST kinda slipped on this one. The 24t sprockets are impossible to find, and the 15t sprockets don't even have a set screw on them....
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
[OCCRA]: Trade for 45-Tooth Sprocket (x2) Silent_Stryker OCCRA 0 27-09-2006 13:25
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Gear Tooth Sensors et1337 Electrical 7 28-01-2006 22:48
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
Gear/Sprocket Help Joseph F Motors 3 18-03-2002 07:48
