Go to Post Pessimism and optimism are both contagious. - Taylor [more]
Unread 28-01-2007, 16:10
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Tuning PID Code
As a side note, I have read that the easiest way to tune a full PID controller is to increase your P constant until there is a constant steady-state error, then increase your I constant until the steady-state error is gone and you have minor oscillation. Finally, increase the D constant to soak up any oscillation.
Hope this helps! We'll have some tuning to do pretty soon ourselves hopefully...
-Sir Francis Bacon
-Albert Einstein
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Problem with idata_user_routines.o? Adrien Programming 3 12-02-2006 01:33
Drive Straight C Code using Encoders without PID? Chris_Elston Programming 17 15-02-2005 23:41
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
