Go to Post This is not an engineering design challenge, this is a project management and common sense challenge with engineering elements. Don't go out of your way to screw yourself. - PayneTrain [more]
Unread 28-01-2007, 17:56
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
pic: 1889's Electrical Module
Unread 28-01-2007, 17:59
foote stepped in
AKA: E. Foote
FRC #0868
Re: pic: 1889's Electrical Module
We did something like that for Triple Play... it was absolutely atrocious. The graduated student whose brainchild it was is now referred to as sadistic, among other things (its easy to blame things upon people who are no longer here)
Anyhow, we found that its now a pain in the rear to trace wires and PWM cables. Makes it very difficult to change or alter anything too....
Best of luck, though!
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 28-01-2007, 19:18
sonofdad123 sonofdad123 is offline
FRC #0996 (Nerd-Uh-Knights)
sonofdad123 is an unknown quantity at this point
tracing wires isn't so hard when you have them labeled ;-)
996 may very well attempt something similar to this, it definitely makes port access to the brain much easier (no bending of serial cables). once those extra cables get cleaned/grouped up a little, it should be a pretty awesome setup.
Team #996 Programmer/President/Comedy Relief
"Why not stop by the robotics meeting after school today?" -Mr. Murray (enlisting me)
Unread 29-01-2007, 18:43
EnderWiggin's Avatar
EnderWiggin EnderWiggin is offline
07' Co-Team Leader
AKA: Carl Partington
None #0610 (The Coyotes)
EnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud of
Are you actually trying to show this off? It looks like my dinner. (spaghetti)
Unread 29-01-2007, 20:17
Nate Laverdure's Avatar
FRC #2363
yummy.
I think it's pretty. I like it, as long as you're confident that you won't have to replace a wire or one of the 40A breakers later on.
Unread 29-01-2007, 20:19
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Mine too. Just a suggestion: you may want to put this away when it gets close to mealtime, people get hungry, and students start scrounging for food. We have found that it will fool the team members if it's hidden in a cardboard box. Whatever you do, don't put it back in the KOP bins--they look too much like pizza delivery boxes. That's where they look first, so they'll find and eat the electronics right away.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 29-01-2007, 21:42
Jaine Perotti Jaine Perotti is offline
...misses her old team.
AKA: BurningQuestion
FRC #0716 (The Who'sCTEKS)
Jaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond repute
Send a message via AIM to Jaine Perotti Send a message via MSN to Jaine Perotti Send a message via Yahoo to Jaine Perotti
The reason why this design is worth sharing is because of it's compact design. The limited amount of space for electronics on the robot was a challenging design problem that Tytus needed to overcome. The object of this design wasn't to make the electronics very neat or pretty looking, or even accessible. The idea was just to save space.
Tytus, do you think you could share a screenshot of the CAD file which shows how components are "sandwiched" between the two plates? This photo doesn't really do it justice.
Florida Institute of Technology
Ocean Engineering, '12
Unread 29-01-2007, 22:34
07' Co-Team Leader
One of the advantages of having such a compact electrical system is that it allows you to have short wires and hence less voltage drop from battery to motors.
If I were you I'd take advantage of this compact design and rewire everything and cut all the wires shorter.
Unread 29-01-2007, 22:44
DonRotolo's Avatar
Back to humble
FRC #0832
I thought short circuits were bad for robots??
Don
Unread 29-01-2007, 22:47
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
Tytus, if you dont clean that up, I will have to come over and fix it.
Hows my searching? Call 1-800-Green-Dots
Unread 30-01-2007, 00:06
Don
He means short wire lengths - i.e. less distance and wire in between terminals.
Unread 30-01-2007, 09:54
Maximus123's Avatar
Maximus123 Maximus123 is offline
Maximus123
AKA: Crimp
FRC #0425 (Team Spartans)
Maximus123 is an unknown quantity at this point
Send a message via AIM to Maximus123 Send a message via MSN to Maximus123 Send a message via Yahoo to Maximus123
Smile Re: pic: 1889's Electrical Module
Make sure there's some breathing room, you dont any victors burning up, and ya, if you need to have it cleaned up, i'll drive all the way from Melbourne Florida to clean it.
Unread 30-01-2007, 10:06
Graham Donaldson's Avatar
Graham Donaldson Graham Donaldson is offline
AKA: Graham Donaldson
FRC #1676 (The Pascack Pi-oneers)
Graham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant future
Don's trying to be funny (I think) (aka short circuit= BOOM!!!-). I like the idea, but shorter wires would definitely be a good idea. Other than that, me like!
2008 NJ Regional, 2009 Palmetto Regional: Chairman's Award Winners
2010 NJ Regional Champions (w/ 25 and 3059), 2010 VA Regional Champions (w/ 1086 & 1418)
"Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all."- Sam Ewing
"Opportunity is missed by most people because it is dressed in overalls and looks like work."- Thomas Edison
Unread 30-01-2007, 23:42
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
I have to say, it seems like a bad plan to me, there's no reason for that kind of wire length and closing the system up like that makes it difficult to work with the lower levels, as far as I can see anyways. Also, it just seems like asking for trouble to leave Victors cramped in like that, in that rats nest of wires, with little ventilation. Also I shudder to think what kind of electrical noise is being rained on the PWM cables you're going to have to install.
Honestly, and no offense, this doesn't seem all that impressive, or even all that compact, or modular given the high probability of tangles.
It's not just a matter of looking bad, it's risky, and ineffective and could cause all kinds of problems later on, all of that traded off for what isn't really much of a space savings compared to most teams set ups (again, as far as I can tell) seems like a terrible idea.
I'm sorry if I seem rude, but I just don't think this is a very effective solution.
Matt Krass
Unread 30-01-2007, 23:50
I agree. I dont care how nice and expensive your parts are.. If you blow a Victor in finals, you're done.
pic: 1889's waterjet nest Tytus Gerrish Extra Discussion 7 17-01-2007 15:42
pic: 6WD Module Madison Technical Discussion 20 12-01-2007 10:09
pic: Completed Mecanum Module Madison Technical Discussion 9 12-11-2006 19:39
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
pic: 494 Power Module KEY Extra Discussion 14 26-01-2005 17:50
