Go to Post kids these days, with their fancy aluminum sprockets, don't know how good they have it. - AllenGregoryIV [more]
Unread 23-01-2007, 11:33
Marcel Marcel is offline
The Fool
AKA: BabyFace
FRC #0059 (RamTech)
Team Role: Scout
Marcel is on a distinguished road
Send a message via AIM to Marcel Send a message via MSN to Marcel Send a message via Yahoo to Marcel
[FVC]: Can you change a vex servo to motor?
The servo module has a large black gear with a stock on it, if we remove the stock will the servo module work the same as a motor module? I heard something that the servo and motor spin their shafts in opposite directions, but I'm not sure I don't want to break it. Anyone know?
Unread 25-01-2007, 19:26
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Re: [FVC]: Can you change a vex servo to motor?
1. That's illegal in FVC. Motors cannot be modified in any way.
2. Why would you want to do it anyway? Just use a regular Vex motor.
If you still want to do it, we did this once a while ago: completely open up the motor, find the potentiometer (which is somehow connected to a gear), and remove it or push it out of the way.
I'm not sure about the stock, and I don't have a motor available to look at. Maybe that's what holds the end of the potentiometer.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 28-01-2007, 13:30
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
As worldbringer said, our team has opened up a servo to try this and it is in fact illegal for vex competions. But if you are just doing this for fun or some other reason, what you can do is either remove the stock from the gear. The stock is what moves the potentiometer or use one of the motor gears that are identical in every way except for that stock. Another method, which we have not tried would be to remove the potentiometer completely, but this could also render the motor useless.
Hope this answered your question.
Unread 28-01-2007, 18:06
7
FRC #1712 (Dawgma)
If you remove it, the correct wires from the pot have to be connected for it to keep working.
Unread 01-02-2007, 00:34
zerozio2u's Avatar
zerozio2u zerozio2u is offline
CAMS
AKA: DemonKing
FTC #3350 (Cheesecake)
Team Role: Student
zerozio2u is on a distinguished road
Send a message via AIM to zerozio2u
you also need some resistors in place of the POT, too.
Unread 01-02-2007, 00:36
zerozio2u's Avatar
CAMS
AKA: DemonKing
Team Role: Student
how would the judge kno if no one tell. but it is all about gracious professionalism.
Unread 02-02-2007, 14:41
7
FRC #1712 (Dawgma)
The judges can tell because the servos are marked as a servo motor on the back. If the motor rotates continuously but says servo on the back, then it's obviously been modified.
Can you have a FVC team without high school affiliation? Bongle FIRST Tech Challenge 16 29-11-2006 08:31
FVC 2005 in Servo Magazine syraweb FIRST Tech Challenge 0 16-02-2006 15:11
Motor to Servo itzrobz Programming 8 02-02-2006 16:11
Can you run a Window Motor on a victor Noah Melamed Electrical 1 07-02-2004 16:11
Can you modlify the tourqe motor? Kyle Fenton Motors 1 21-01-2002 00:57
