Go to Post Part of being an effective leader is knowing your own personal limits. - artdutra04 [more]
Unread 28-01-2007, 19:57
pufame's Avatar
pufame pufame is offline
FRC #0291 (CIA)
Team Role: Webmaster
pufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud ofpufame has much to be proud of
pic: 291 Gripper w/ tube
Unread 28-01-2007, 19:58
Jaime65's Avatar
Jaime65 Jaime65 is offline
AKA: Jaime
FRC #3398
Jaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud of
Re: pic: 291 Gripper w/ tube
what row is this gripper designed made to score on
2015 • Team #3398 Crushing Crusaders • Mentor
2008 – 2009 • Team #65 Huskie Brigade • Mentor
2003 – 2007 • Team #65 Huskie Brigade • Human Player
Most Of The Time You Will Fail, But You Will Also Occasionally Succeed.
Those Occasional Successes Make All The Hard Work And Sacrifice Worthwhile. - Dean Kamen
Unread 28-01-2007, 20:03
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Out of curiosity, why do you want to pivot the tube to be parallel to the spider leg?
Unread 28-01-2007, 20:06
Rafi Ahmed's Avatar
Rafi Ahmed Rafi Ahmed is offline
Mentor & Alumni
FRC #2522 (Royal Robotics)
Rafi Ahmed has a spectacular aura aboutRafi Ahmed has a spectacular aura about
Im not sure what 291 is going to do but if you have the tube parallel with the spider leg and have it on top and let it go it should swing into position. Just cant take them off.
Team 2522 | Mentor
Formerly of Team 22 and Team 4
Unread 28-01-2007, 20:09
Originally Posted by the other picture
The entire assembly then pivots to make the tube parallel to the spider legs.
I interpreted this as meaning "parallel to the spider leg foot" or "vertical", rather than "horizontal", since the entire assembly already seems to be in the horizontal position. Let us see what the clarification on this issue yields.
Unread 28-01-2007, 20:13
Andrew Blair's Avatar
FRC #0306 (CRT)
Judging from the apparent hinge on the assembly's attachment point to the lift, I think he means that the tube's center will be concentric with the spider leg. Such that they can pick up off the floor, yet need less height to get to the top rung. But, dropping it over the stinger isn't a bad idea either.
-Sir Francis Bacon
-Albert Einstein
Unread 28-01-2007, 20:18
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
My team has found that placing the tubes on the goals in the horizontal orientation is much easier, and they will just fall into place when you release them over the stinger. Looks like a solid system for picking the tubes off the floor.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 28-01-2007, 20:27
pufame's Avatar
FRC #0291 (CIA)
The purpose of the assembly's ability to swing up was for the ability to take rings off of the rack and a bit less height we would have to achieve with our lift mechanism. Although, this pivot is probably the most hazy in our design at the moment and may be dropped in the end, we may end up just sort of dropping the tube over the rung as mentioned earlier in the thread.
Unread 28-01-2007, 20:30
pufame's Avatar
FRC #0291 (CIA)
Another note, the entire mast pivots back to a 45 degree angle to allow for storage withing the 4 foot starting requirement. This is much like our 2005 Tetra robot if anyone was at the Pittsburgh regional and remembers.
Unread 28-01-2007, 20:31
pufame's Avatar
FRC #0291 (CIA)
Bottom and Middle, Not meant for top at the moment however if we end up underweight it is a possibility though unlikely.
Unread 28-01-2007, 20:46
Thanks for the clarifications, but don't forget you can just edit your posts instead of posting three times in a row.
Unread 28-01-2007, 22:35
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
The grippers are going through the tube itself. Will that be a problem later on?
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 29-01-2007, 13:32
pufame's Avatar
FRC #0291 (CIA)
That only happens in the inventor file, the tube didn't like to constrain to the curved surface correctly. We did the calculations by hand, it will go over the tube as it should. And I know I can edit posts, I just took a mental holiday I suppose...
pic: 1881 tube interface idea GMAdan Extra Discussion 13 22-01-2007 12:08
pic: Team #8's Tube Interface dfukuba Extra Discussion 5 13-01-2007 02:04
pic: Height on top of a tube Jeff Rodriguez Extra Discussion 21 13-01-2007 01:46
pic: Team #8's Tube Interface dfukuba Extra Discussion 13 13-01-2007 01:16
pic: 469 Gripper Alex Golec Robot Showcase 9 30-03-2005 21:06
