Go to Post Because when you build the people and the team, building the robot comes much easier. - Koko Ed [more]
  #31   Spotlight this post!
Unread 13-01-2007, 21:54
banebots banebots is offline
banebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant future
Re: 2007 Motor Specs
We have posted drawings of the 36mm and 42mm gearboxes on our website. You can find a link to them at the bottom of the product descriptions.
BaneBots
  #32   Spotlight this post!
Unread 14-01-2007, 02:42
GramNegative GramNegative is offline
FRC #1816
GramNegative is an unknown quantity at this point
Earlier, Rickertsen2 posted a formula for motor output torque using these calculated values:
torque = Kt*(Vin-Kv*rpm)/r
Does anyone know if there is there an advantage to using this formula over:
Torque = (-T0/Wf)*W+T0, Where T0 is torque at stall and Wf is free speed
If so, is there more documentation somewhere that explains how/why this works better?
Thank you,
Chris
  #33   Spotlight this post!
Unread 14-01-2007, 02:48
President, VEX Robotics, Inc.
Thank you,
Chris
The equation using torque constant (Kt) and back EMF constant (Kv) is the theoretically pure way to calculate motor performance. However, most motor manufacturers will not give you all of these numbers. All motor manufacturers will give you stall T, free speed, Stall current, and free current (no load current) and it is all you need to size motors and gearboxes for the job.
  #34   Spotlight this post!
Unread 14-01-2007, 03:11
FRC #1816
Thank you for the help. Now that my curiousity is satisfied, I think it's time for bed.
  #35   Spotlight this post!
Unread 28-01-2007, 11:32
darkorbit's Avatar
darkorbit darkorbit is offline
Electrical?!
AKA: Jin Lem
FRC #0069 (HYPER ROBOTICS)
darkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to all
Does anyone have the specs for the window motor or more importantly the connector for the window motor? Or if someone can tell me how do I hook up a window motor, that would be highly appreciated.
2007 BOSTON REGIONAL WINNERS (NU-HYPER-FORCE)
2008 Florida Regional 2nd Place
  #36   Spotlight this post!
Unread 28-01-2007, 11:59
bmusser bmusser is offline
Brian Musser
FRC #1504 (Desperate Penguins)
bmusser has a spectacular aura aboutbmusser has a spectacular aura aboutbmusser has a spectacular aura about
Go to the following link for the motor specs:
http://www2.usfirst.org/2007comp/oth...tices_RevA.pdf
The motor specs are on page 8.
  #37   Spotlight this post!
Unread 28-01-2007, 22:03
Generator of Entropy
FRC #2973 (The Mad Rockers)
I don't know the specs on the connector, but here's how we've done it in the past and it works just fine (I'll probably get kicked out of the junior EE club for these instructions):
Using a hacksaw or coping saw, cut the plastic housing of the connector back to the bottom of the socket, and then cut it lengthwise between the two conductor pins and basically break the plastic away. This will leave you the 2 pins which are about a half inch long sticking out. Solder your power wires to these 2 pins and wrap with electrical tape.
  #38   Spotlight this post!
Unread 28-01-2007, 22:12
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
The way Gary explained it, it will work. To make your life easier, there are connectors that comes in the KOP for the window motors. You can use those.
  #39   Spotlight this post!
Unread 31-01-2007, 16:43
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
i've found that a lot of the motor specs are on the respective companiess pages. If you can't find what you need, try looking there. I've found it very helpful!
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
  #40   Spotlight this post!
Unread 05-02-2007, 11:20
natis's Avatar
natis natis is offline
natalia
AKA: natalia soberanes
FRC #0987 (High Rollers)
natis has a spectacular aura aboutnatis has a spectacular aura aboutnatis has a spectacular aura about
Send a message via MSN to natis
stupid question:
I was trying to find the connectors for the banebot motor does anyone has a website ???
thanks
natalia
Team 987 - The High Rollers - Las Vegas, Nevada
2002 -- Nationals Highest Rookie Seed
2003 -Xerox Creativity Award
2004 -LA Regional Semi-Finalists
2005 - Arizona Regional Finalists -- GM Industrial Design Award -- Las Vegas Regional Champions
2006 - Delphi "Driving Tommorow's Technology" Award -- Radio Shack Innovation in Control Award
2006 - Las Vegas Regional Champions -- Arizona Regional Finalists
2007 -Motorolar Quality Award
2007 - SVR semifinalist -- Las Vegas Regional Finalist
2007 --WORLD CHAMPS!!!
  #41   Spotlight this post!
Unread 12-02-2007, 16:40
techknow 1685 techknow 1685 is offline
FRC #1685
techknow 1685 will become famous soon enoughtechknow 1685 will become famous soon enough
Hello,
I just registered to cheif delphi, so i am new at using this site.
I hope i am doing this right.
Anyway, does anybody know what kind of what kind of motors can we use for the robot?
Can we use a motor from power drill?
  #42   Spotlight this post!
Unread 12-02-2007, 19:03
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Originally Posted by techknow 1685 View Post
Hello,
You can use the motors in the kit plus two additional small CIM's and one additional large CIM.
Team 1062, The Storm, 2003
Motor Specs??? tenfour General Forum 1 10-01-2003 17:56
motor specs? Gary Dillard Motors 0 04-01-2003 17:54
What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. Robb Gerber Motors 2 23-01-2002 08:58
Chiapua motor specs? Nick Boyajian Motors 2 09-01-2002 06:14
Motor specs kmcclary Off-Season Events 4 26-10-2001 22:41
