Go to Post Moral of the story: Crashes happen, things break... SHIFT HAPPENS. - Qbranch [more]
Unread 28-01-2007, 22:33
dtengineering's Avatar
AKA: Jason Brett
Re: Transciever problems
The latest Team Update from FIRST indicates that there are some radio problems which IFI is working out, and which are also discussed here http://www.chiefdelphi.com/forums/sh...ighlight=radio
As for the tethering, remember that you have to use the red cable to make a tether connection. You can extend it using black serial cables which will allow you to do a little test drive without the radio, just remember to anchor the cable on the robot so it doesn't pull on the tether plug of the RC if your robot goes a little farther or faster than the cable will allow.
We expereience some glitching with our new radios on Saturday, switched to last year's and everything seemed to work out okay. Not much help if you don't have old radios to fall back on, though.
Jason
Unread 28-01-2007, 22:42
Originally Posted by dtengineering View Post
...remember to anchor the cable on the robot so it doesn't pull on the tether plug of the RC if your robot goes a little farther or faster than the cable will allow.
It took me a couple of tries just now to read that correctly. I was about to say something about not securing the tether, but you're talking about fastening the cable to the frame of the robot so that there's never any tension put on the tether connector. That's good advice. But also remember to make it easy for the other end of the connection to come apart so you don't end up breaking the OI connector -- or, worse, dragging the OI along the field -- if the robot pulls the cable tight.
Unread 28-01-2007, 22:58
AKA: Jason Brett
Yes, you read that correctly... we had some fun at GTR a couple years ago when one of the test drivers got just a little bit excited... the tether cable was screwed in tight to the RC, and as the robot drove away it ripped the tether port almost completely out of the RC.
That left us able to compete, but unable to pre-charge our pneumatics or do any further testing in the pits. Thankfully we got some help from our friends on 1241 and the IFI folks, and were back up and running by the end of the day.
Lesson learned... lesson shared.
Jason
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Problems muy dificil Programming 5 26-10-2005 17:10
PC problems. . . opnickc IT / Communications 5 12-01-2005 16:53
Problems- archiver 1999 0 23-06-2002 23:00
Problems, problems . . . archiver 2000 6 23-06-2002 23:00
