#16
Re: small banebot motor with 64:1 gearbox
We are using two 64:1 42mm Gearbox w/ the FP motor to power our forklift. Two 64:1 36mm Gearboxes will be powering the "arm".
We'll tell you how well it goes later this week. We realized the best way to see if it'll work is to try it, then go from there. If there isn't enough torque, then we'll get different gearboxes..... |
#17
Low enough gearing combined with a PID algorithm (which is much simpler than you may think) will work. |
| opening up the BaneBot gearbox to install the CIM motor | jskene | Motors | 9 | 22-01-2007 11:12 |
| Banebot Gearbox | chris31 | Technical Discussion | 45 | 15-01-2007 17:56 |
| 56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? | VEN | Technical Discussion | 4 | 11-01-2007 14:45 |
| Drill Motor Max RPM with Gearbox? | archiver | 2001 | 1 | 23-06-2002 22:40 |
| What with the small motor? | Robb Gerber | General Forum | 10 | 10-01-2002 14:10 |
