Go to Post Try to remember, FIRST is like life, it is about the journey not the destination. - rees2001 [more]
Unread 27-01-2007, 09:52
Matt21q Matt21q is offline
FRC #0810
Matt21q is an unknown quantity at this point
Knocking Down Ringers Strategy
First of all I would like to know if this strategy is legal, and second of all, I would like some opinions on the idea itself.
The match would begin with my team's robot right next to the opposing team's ringers facing parrellel to the wall. When the match begins, a piston shoots out and the robot moves foward knocking down the enemy ringers.
My team thought that this strategy would make it harder if not impossible (depending on the opposing robots) for the other team to use the nine ringers at the opposite end of the field.
Unread 27-01-2007, 10:19
QoutedClevrLine QoutedClevrLine is offline
AKA: Carol
None #0075 (Roboraiders)
QoutedClevrLine is an unknown quantity at this point
Send a message via AIM to QoutedClevrLine
Re: Strategy
It is legal, but you must lose possesion of your keeper before you do that.
Unread 27-01-2007, 11:06
FRC #0810
Re: Knocking Down Ringers Strategy
Would I have drop my keeper if I set my robot to do this during autonomous mode?
Unread 27-01-2007, 11:14
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Game rules generally apply to both autonomous and driver-control mode.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 27-01-2007, 11:19
Hieb Hieb is offline
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
The strategy has some pros and cons:
Pros:
1. It may make it more difficult for some opposing bots to pick up the ringers.
2. It could be used to clear your own home zone for the the end game so teams deploying ramps wouldn't get hung up on a ringer during deployment.
Cons:
1. Unless you can knock them down AND hang your keeper, you are throwing away the potential of an unspoilable position. (On the other hand, if you have difficulty scoring the keeper in the first place, this really isn't an issue)
So depending on your approach to the game, this strategy has potential.
Unread 27-01-2007, 18:33
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
The only other possible con that this strategy might have is that if one of the tubes falls in front as your robot as it continues to drive, you may be contacting two or more tubes at once as you drive to knock them all down. This would most likely get called by the referees as a penalty for controlling multiple tubes.
Art Dutra IV
世上无难事,只怕有心人.
Unread 27-01-2007, 20:52
Back after 4 years off
FRC #5279
You could probably get away with this once but after that you would probably be out of luck.
Also alot of teams will be designing to pick up tubes that are laying down because flat on the ground is the easiest repeatable posistion for all 18 ringers. This may not always be a good strategy.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 27-01-2007, 21:40
Best Available Data
FRC #1778 (Chill Out!)
http://forums.usfirst.org/showthread.php?t=1520
This strategy may be both helpful and harmful to your opponents (as James has already said). And your opponent may even do this for you.
Unread 29-01-2007, 02:06
EricH EricH is online now
And there was also a You Make The Call about this.
Unread 29-01-2007, 08:05
JustinMilne's Avatar
JustinMilne JustinMilne is offline
FRC #1901 (Ram Rod)
JustinMilne is an unknown quantity at this point
this wouldn't be helping you team because the floor is a constant angle but the rings on the wall are at different angles so automated robots would need to move the rings to the floor any way so you would only be interfering with rookie teams and teams that don't have time to program. I think that this wouldn't be a good stratagie because you will likely be wasting your keeper.
Unread 29-01-2007, 08:13
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
Knock them down and then protect like crazy. If they can't get them for any reason, then they are limited to the 9 ringers they get from players on their side.
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
Unread 29-01-2007, 09:49
Vapo7's Avatar
Vapo7 Vapo7 is offline
FRC #0365
Vapo7 is an unknown quantity at this point
This will not neccesarily be called by the referees during the match. It is only if there is intentional herding of the tubes during the match that can be called. In the FIRST Q&A forums a question concerning multiple contacts of tubes was brought up and it was answered that if it is not intentional, then the team would not be penalized. So, if the tubes were being knocked over and not "herded" then the plan shouldn't be penalized.
Unread 29-01-2007, 10:18
Synergy1848's Avatar
Synergy1848 Synergy1848 is offline
Vex Career: 84-20-1
AKA: Tony
FRC #1848 (SOUP)
Synergy1848 will become famous soon enoughSynergy1848 will become famous soon enough
smart teams won't rely on getting the tube from the wall in the position they start in.
what happens when your allinace parter stays in thier starting position in autonomous mode?
FRC# 1848 Team Soup
2007 Peachtree Winner 2008 Peachtree Imagery Award Winner
Mr. Roboto and Super Pals
2005 FVC 24 finalist, 2007 FVC 2024 NC winner, Champs 3rd seed; semi-finalist
2008 FTC 3 Tn Winner, Inspire award, Motivate award Ga Finalist, Amaze award Champs '08 Franklin
Unread 29-01-2007, 12:33
akshar's Avatar
akshar akshar is offline
FIRST=life
AKA: Fro
FRC #1568 (Mechanicatz)
akshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to all
Send a message via AIM to akshar
Chris
what happens if a fast thinking coach sends over two robots to get tubes? your robot wouldnt be able to protect the tubes from both bots
Think Bot, Dream Bot, Be Bot
Dream Big Reach High
2005: UTC Judges Award (We'll be Back Award)
2006: Boston Regional Winners with 121 and 233
2007: Boston Regional Finalists with 1626 and 121
Unread 29-01-2007, 13:36
FRC #5279
Chris
They are limited to 9 ringers (assuming they can't get by you(Odds are a good team of robots could get atleast a couple from you. But you are limited to 2 robots actively playing the game.
I am all for defensive strategies but unless you can block all 18 ringers you are better off defending the rack and stopping teams from scoring than you would be defending half the ringers. it is much easier to try to block a robot from doing the much more exactl manipulation required to score than it is to stop them from picking up one of 9 rings. 26 feet across the field is alot of space to defend.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Knocking down opponents ringers Caseavong Rules/Strategy 6 08-01-2007 17:43
White Paper Discuss: Simple strategy/couter-strategy sheet CD47-Bot Extra Discussion 2 06-04-2004 22:37
Knocking Down The Whole Stack... Suike Regional Competitions 39 30-03-2003 19:33
Image Discuss: Team 60 - Knocking Down Boxes 1 CD47-Bot Extra Discussion 7 12-02-2003 11:05
Knocking Over Boxes oneeightytwo Rules/Strategy 5 10-01-2003 15:23
