Go to Post When you start new threads, keep in mind that ChiefDelphi has about 14.6 million subforums about nearly everything you can imagine in the world of FIRST. You have to be in the forum you'd like for your thread to appear in when you choose to start a new topic. - Madison [more]
Unread 17-01-2007, 00:02
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Camera Pan Angle Problem
I zero'd out our camera servos by setting them to the default pan and tilt PWM values as per Kevin's default cam code, then built the camera around them. The code says that the camera should pan within about a 130 degree angle (+/- 65 from center), though ours goes only about 80 (+/- 40).
It's really disadvantageous as the camera loses the light very easily off to the sides with this small range. We'd really like to see it get the full range of motion. Any ideas?
What place are we at? ... TODAI!
Unread 17-01-2007, 08:48
Re: Camera Pan Angle Problem
John,
Check the specs on the servo you have mounted for pan. It may be the restricting factor in pan angles.
Unread 29-01-2007, 11:56
jdejoannis jdejoannis is offline
FRC #1845
jdejoannis will become famous soon enoughjdejoannis will become famous soon enough
I am having a similar problem with both pan and tilt not exploring the full range of motion. The camera likes to look up and to the right. Are there some calibration settings for the servos? We are using the default bells and whistles code, the 2007 camera and the 2006 pan/tilt assembly.
Jason
Unread 29-01-2007, 12:25
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Jason
You can use the code discussed here to drive your servos past the range the RC would normally provide by using gains higher than 50 (5.0us). Towards the end of the thread I discuss a method to precisely tune the range and center position of your servo(s). I found that I needed a gain of 36 to rotate the servo shaft 90 degrees, which implies that you need around twice that to get the full range.
-Kevin
Kevin Watson
http://kevin.org
pan/tilt connection for 2007 camera kasemodz Programming 5 21-01-2007 14:21
Camera angle - interesting question TEAM1949 Programming 3 08-02-2006 22:20
White Paper Discuss: Assembly of the 2006 pan/tilt camera mount Justin Stiltner Extra Discussion 2 09-01-2006 11:17
Viewing Angle of Camera Joe Johnson Technical Discussion 10 14-01-2005 14:11
Webcast camera angle... Joe Johnson Regional Competitions 13 11-03-2002 16:35
