Go to Post The more time we spend there, and the more investment we have in the team, the more rewarding it is. - ILAMtitan [more]
Unread 29-01-2007, 13:13
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Banebot 56mm gearbox - double D related
There are threads here, here and here that are all discussing the same issue. Will the double D joint between the last carrier and the output shaft survive?
There are sub-questions:
Will the 12:1 1 CIM joint fail? If so what can be done to fix it?
Will the 16:1 1 CIM joint fail? If so what can be done to fix it?
Will the 12:1 2 CIM joint fail? If so what can be done to fix it?
Will the 16:1 2 CIM joint fail? If so what can be done to fix it?
We can debate who is to blame and how could this have happened all day long. It is not going to get us the answers to the question, nor is it going to get us to a solution.
Here is the state of things:
Data Point 1: Hardness test of shaft and carrier:
Output shaft: RC 23, RC 23.3, RC 23.2
Carrier Plate with D: RA 45.9, RA 46.9, RA 45.8
Rockwell C to Tensile Yield:
RC 22 – 115 Ksi
RC 23 – 117 Ksi
RC 24 – 119 Ksi
RC 25 – 123 Ksi
RC 26 – 125 Ksi
Rockwell A to Tensile Yeild:
RA 45.0 – 62 Ksi
RA 45.5 – 63 Ksi
RA 46.0 – 64 Ksi
RA 46.5 – 65 Ksi
RA 47.0 – 66 Ksi
RA 47.5 – 67 Ksi
RA 48.0 – 68 Ksi
Data Point 2: Calculations & Date = Prediction
Using calculations + above hardness tests of the joint, I predicted that with the 12:1 gearbox should fail at about 3.1N-m input into the gearbox. Since 3.1N-m = 28in-lbs = roughly 1.5X CIM_stall_torque, alarm bells began ringing.
Data Point 3: static failure test
Using a test set up and a torque wrench, I was able to determine that the join failed with a single loading of between 3X and 5X CIM_stall_torque. This is better than predicted but not that encouraging considering that the "failure" was basically a spungy type event, allowing for actual failure to begin at lower than 3X. See picture.
Data Point 4: Cycling Failure test
Using the same test set up, I was able to show that the joint will fail at 2X CIM_stall_torque with repeated loading. See Picture.
Data Point 5: Failure in the field
This still did not mean that teams would see failures in the field because we don't know the dyanmic loading that we expect to actually see during real world conditions. I typically use 2x as the dynamic load factor, but that is not a law of physics it is just a rule of thumb. So... ...we needed confirmation.
Team 166 uploaded a picture that confirmed this problem will be seen by teams. This is after 3 hours of driving. Team 166 did not say what ratio & how many CIMs they used, but I suspect it was 16:1 with 1 CIM. Will someone from 166 confirm this please.
Where do we go from here?
Now, what do we have to do going forward? I believe that we can get a quick 2X in the output by simply getting harder carrier plates (RC 23 or higher). I believe that will almost certainly get us to the 12:1 1-CIM case as well as the 16:1 1-CIM case.
What it does to the 2 CIM cases, I can't predict. My best educated guess is that for most teams the this will address the problem for the 2-CIM cases too, but I have to be honest, the picture from 166 has me worried. If they were in fact using the 16:1 1-CIM set up, then going to a 2X hardness will be exactly matched by a 2X in loading due to the 2-CIMs.
We need more testing and we need more thought on solutions.
More Information
For your information, Banebots is well aware of this. They are working hard with FIRST, their suppliers, and yours truly to get a good solution out there to teams. Everyone is sorry. Beating us all up will not help. Calling them will only take time away from fixing the problem. We are working on it.
Joe J.
Name:	56mm 12to1 final Carrier 1 cycle at 60-100in-lbs aaa.JPG
ID:	4954  Click image for larger version
Name:	56mm 12to1 final Carrier 100cycles at 40in-lbs ccc.JPG
ID:	4955  Click image for larger version
Team #88, TJ2
Unread 29-01-2007, 13:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Banebot 56mm gearbox - double D related
In the pictures of the failed plates, it looks like the shaft is not fully engaged with the plate. In addition to hardening the plate, it might be worthwhile to look into some type of mod to the shaft to get full engagement.
Unread 29-01-2007, 13:39
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
May I add that this same problem is happening with the 42mm gearbox's, which many teams planed to use with the FP motor to power an arm. It will fail on you quicker than the 56mm drive gearbox's. If I was on or mentoring a team planing on using these gearbox's I would tell them to grab a pair of single speed Andymark gearbox's which for the same price accept 2 CIMs or 1 Bike CIM and 1 CIM.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 29-01-2007, 14:40
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
I have been following the banebot transmission failure threads for some time now and now I feel teams need to take action.
We are currently running 2 CIMs on each gearbox...so we definately need to get parts made. At the moment are transmissions are on the robot and not easily accessable, but we will get to them to replace the Double D plate. We have yet to have an issue...but are going to take precautions now.
Does anyone have a CAD drawing of the piece that needs to be made?
It is my hope that teams which have the resources...get many of these plates made to help out other teams who are not as lucky.
I would love to not have to worry about it and wait for BaneBots, but their response time (at least with me) was not acceptable. Teams need to start production now so the plates can be replaced BEFORE regionals.
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 29-01-2007, 15:30
dapub dapub is offline
FRC #1991 (The Dragons)
dapub has a spectacular aura aboutdapub has a spectacular aura aboutdapub has a spectacular aura about
Is this a problem only with a 2 motor setup? Should we be concerned if we are just using one CIM per gearbox?
Unread 29-01-2007, 15:45
cbpetrovic's Avatar
cbpetrovic cbpetrovic is offline
AKA: Mr. P
FRC #0166 (Chop Shop)
cbpetrovic is a jewel in the roughcbpetrovic is a jewel in the roughcbpetrovic is a jewel in the rough
Send a message via AIM to cbpetrovic
Dr. Joe.
We are using 1 CIM w/ 12:1 ratio.
An ME here would like to know how you calculated the stress. Below is his observation from the photos as well as conversations with me.
"The initial interface is 2 lines of contact (essentially zero area) between the shaft and the D hole. It is only after material begins to deform (ever so slightly) that area contact is made. I am curious what he uses for stress area and how he determines it."
C. B. Petrovic
Unread 29-01-2007, 15:48
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Is the double D shaft pressed into that plate, or it just sits in there? Howabout the planet pins? This part that fails is just a 2D geometry plate? Is it easy to swap out? We have a lasercutting sponsor. There is a chance we may be able to set up a large production run of lasercut plates available for a small cost. Is laser accurate enough (draft angle)? What kind of material would it take to make this plate never break? How would it have to be treated/hardened? Joe, talk to me. I want this to be a good year for FIRST. A robot that drives without worry is the key to success.
Unread 29-01-2007, 15:49
AKA: Dr. Joe
FRC #0088 (TJ2)
From the data we have to this point, it looks like it could be a problem over time for even the single motor CIM drives if driven hard back and forth for many cycles. I think it will take significant cycles to fail but based on the experience of Team 166, I think it will fail.
The good news is that when it fails it doesn't seem to take the rest of the gearbox down with it. It is not ideal but it is something.
Joe J.
Team #88, TJ2
Unread 29-01-2007, 15:57
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by cbpetrovic View Post
Dr. Joe.
C. B. Petrovic
I assumed a linear stress distribution normal to the joint surface starting at the center line and increasing to a peak at the corner of the D. I then integrated the torque to get the sum (on both sided of the D) which had to resist the torque on the joint. I found an engineering rule of thumb that allowed me to estimate failure of the joint by saying the material will start moving at 1.5X the tensile yeild stress. Once the material begins to move, the stress distribution changes but the joint is losing the battle. So I used the torque that made my linear stress distribution have a stress in the corner greater than 1.5X Stess_Tensile_Yeild
I hope that helps.
Joe J.
Team #88, TJ2
Unread 29-01-2007, 19:48
flightofone flightofone is offline
AKA: John Clayton
FRC #2104 (Colonel Robotics)
flightofone is just really niceflightofone is just really niceflightofone is just really niceflightofone is just really niceflightofone is just really nice
Send a message via AIM to flightofone
Re: Banebot 56mm gearbox - homebrew hardening?
Would a homebrew hardening of the plate be of use in helping this problem? Heating it to red-hot and tossing it into a bucket of cold water seems like a fun experiment. Into potentially explosive oil could be even more exciting (just kidding, this could/would be very dangerous). http://www.efunda.com/processes/heat...ing/direct.cfm
There's a fine line between fishing and just standing on the shore like an idiot. - Stephen Wright
________________________________________
2007 UTC Regional - Finalists (thanks 25 & 176)
Unread 29-01-2007, 20:20
Cascade Cascade is offline
Intermittent Mentor
Cascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to behold
Is there any possibility FIRST would let us use last year's transmissions as a solution?
This is so bad I can't even understand how this mistake could happen. We have been planning for a year and getting ready for this year’s competition and we may be sunk before we even take the field. Why were these things not tested before the switch was made?
boooo
Unread 29-01-2007, 20:30
cbpetrovic's Avatar
AKA: Mr. P
This plate looks like it could be manufactured out of 4140 pre hard (Rc 28 - 32) fairly easily. 4140 Rc 28 - 32 should give Sy of around 120 - 130 ksi. A wire EDM could do all features with high precision. Comments?
Could you provide drawing for us to use?
thanks
Ron Reich 166
Unread 29-01-2007, 20:38
AKA: Dr. Joe
FRC #0088 (TJ2)
I have been talking with a lot of folks. A plan is starting to take shape.
I have 2 teams that have agreed to do some additional testing for us (thanks to #1279 & #1618).
By the way, I have confirmed that FIRST had these gearboxes almost 9 months ago and they say they did extensive testing on real robots with both the 1-CIM and 2-CIM set up. It is still possible that the one confirmed field failure is a fluke of some kind and not representative of the loading we expect to see in the field.
We will work hard to understand the extent of the problem and to come up with a way to address the issues.
Joe J.
Team #88, TJ2
Unread 29-01-2007, 20:52
Is there any room to make the plate thicker? Or, what if we go to hex instead? Forgive me, I haven't actually looked inside the thing yet.
Unread 29-01-2007, 21:12
haroony341's Avatar
haroony341 haroony341 is offline
FRC #0341 (Wissahickon HS & NMTCC) FRC#2234 (The Episcopal Academy)
haroony341 is an unknown quantity at this point
Send a message via AIM to haroony341
team 2234 at Episcopal Academy had originally planned to use Banebot's dual CIM gearbox attached to the 56mm planetary gearbox but we no decided to scrap the idea, and go with AndyMark's dual speed transmission. more than just the double-D connection, the larger sized gears in the planetary box were worn down almost instantly. we had only done a few tests with no load at all and the gearbox just locked up. we found that the one of the gear's tooth was bent. we chipped it off as a temporary solution. but a few days later, after just one failed load test, it locked up instantly, and each of the gears had something wrong with it.
hopefully we'll have better luck with the new transmissions
Drexel University Class of 2009 -- Computer Engineering
Team 341 Miss Daisy // Wissahickon High School @ NMTCC
http://www.team341.com
Team 2234 // The Episcopal Academy http://www.ea1785.org/robotics
small banebot motor with 64:1 gearbox burkey_turkey Motors 16 29-01-2007 01:48
opening up the BaneBot gearbox to install the CIM motor jskene Motors 9 22-01-2007 11:12
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
Attempting to Cut BaneBot 56mm Shaft edthegeek Motors 6 15-01-2007 08:51
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
