#16
Re: Rulings for modifying joysticks in 2007?
I have some experience using accelerometers for user input (in fact I'm working on a project to do just that at this very moment!), and with some processing, the results are quite good. However, you need to sample MUCH faster than the 38Hz that the OI does in order to get decent double integration precision. That would require an external processor, which would require power, which we don't have.
| Voltage-to-resistance converter for using any joysticks | ConKbot of Doom | Control System | 14 | 15-07-2006 12:13 |
| guidelines for modifying the linker script??? | gnormhurst | Programming | 2 | 06-03-2005 02:03 |
| Neutral for joysticks isn't 127 | DemonYawgmoth | Programming | 15 | 23-02-2004 16:47 |
| AVB joysticks..and other analogue joysticks | tml240 | Kit & Additional Hardware | 6 | 07-02-2004 12:45 |
| reworking radio control for joysticks | ajlapp | Electrical | 5 | 05-12-2003 17:38 |
