Go to Post It is probable that you will find mroe than a few spotlight worthy phrases or sentences in the following. ;) - sanddrag [more]
Unread 29-01-2007, 13:47
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: CMU2Cam Degrees & more
Originally Posted by Lablabla View Post
Hi,
I'm Using the streamlined version downloaded for kevin.org/frc
Is there a way to find out the degrees the pan and tilt are in relation to the horizontal and vertical zeros? (i.e camera looking straight forward)
In Kevin's code he lists the degrees for each range if using the pan/tilt mechanism for FIRST in tracking.h (for example, the pan servo goes from 0 to 248, and has a total range of 130 degrees). To determine the value your 0's are at, you will have to manually control the camera until it is in the position you want to be considered "center".
Originally Posted by jdejoannis View Post
How do you drive the servos? This would be very useful for us to debug something.
The servos are driven with standard pwms, so instead of having the camera code create the pan & tilt pwms, have a joystick control the value of the pwm. Comment out servo_track() so the camera has no control of the servos, then do pwm01 = p1_y (with whatever pwms and joystick you want to use inserted there).
Servo Values to Degrees... How? mogunus Programming 16 11-04-2007 02:03
engineering degrees sciguy125 Career 18 17-03-2006 23:44
Turn 90 Degrees Mike Math and Science 16 05-12-2004 22:22
More Pictures & Movies of Team 121 Kyle Fenton Robot Showcase 9 18-02-2003 23:51
TRADE ITEMS--EXCLUSIVE--MOE'S SIGNED SOCKS & MORE archiver 1999 2 23-06-2002 22:37
