Go to Post I think if you talk with mentors of FIRST teams, you will find that they have changed the world. - Bill Moore [more]
Unread 29-01-2007, 15:02
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Post Re: Banebots 42mm gearbox: Recommendations for use
Thanks so much for your efforts to analyze and solve this problem over the past few days, Dr. Joe. My team is in the "fortunate" situation of having a 12:1 single CIM drive system, but I am worried about our arm which is driven by the 256:1 42mm transmission with FP motor. While I don't anticipate the motor ever being driven to anywhere near stall, I tend to think that impulsive loading from the arm itself is the thing to watch out for.
I can easily imagine a large arm changing directions in a matter of milliseconds, hitting a dead stop, or gaining momentum before a chain engages and suddenly yanking on the drive shaft with much more torque the the FP could supply. And at 256:1, the gearbox would have very little give from backdrive at those time scales. A good test might be to short the motor terminals (worst-case scenario with Victor e-brakes on?) and drop a weight from an arm attached to the shaft. I bet it could do a lot of damage.
If this is the more likely way to get failure, then there are a bunch of ways for teams to alleviate the problem, many of which were mentioned in previous threads (gas springs, limit switches, etc.). Do you think this could be the more dangerous culprit, or am I missing something important?
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Banebots 36mm gearbox: Recommendations for use Joe Johnson Motors 2 02-02-2007 17:10
Strange noises from the BaneBots gearbox/CIM combination. PhilBot Motors 5 15-01-2007 11:15
42 mm Banebots Gearbox Hunter Motors 9 13-01-2007 21:52
2007 BaneBots 52mm Gearbox is posted ! Ed Sparks Inventor 3 09-01-2007 07:38
Recommendations for 6-amp battery chargers kiettyyyy Electrical 12 25-07-2006 01:37
