Go to Post Mark McLeod, one of the resident experts on compiler weirdness - Kevin Watson [more]
Unread 29-01-2007, 16:16
Guy_E Guy_E is offline
FRC #1574 (MisCar)
Guy_E has a spectacular aura aboutGuy_E has a spectacular aura about
Send a message via MSN to Guy_E
DB9 Port problem
Hi,
I have a weird problem. I tried to connect the camera to my laptop with a serial cable, but neither Labview nor the JAVA software recognized the camera. I verified that the camera was working (the 2 LED were working) and verified that my COM port configurations are as they supposed to be. My COM port is fine because I can download programs to the controller with it.
Does anyone has an idea what could be my problem?
Thanks,
Guy
Team #1574 Misgav High School - Israel
Winner of the 2007 Israeli Regional
Winner of the 2007 Motorola Quality in Design Award
Visit our website:
www.miscar1574.com
Unread 29-01-2007, 16:21
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: DB9 Port problem
Is your camera connected to your robot, through serial?
Make sure the only things that are connected to your camera are power and your serial cable for the computer. Verify your serial cable by using it to download to the robot; note which port IFI loader is using. Then, *close IFI loader* (it will block the port if the terminal window is open) and try using that port to communicate with the camera.
It is possible you have a bad camera board; if these tests reveal nothing, I'd consider contacting FIRST (well, is IFI responsible for CMUcams? I don't know for sure...) and see about getting a new camera.
Does your team have an old camera? The boards from 2005 and 2006 are identical (except for the servo output pins) to this year's board.
Good luck,
JBot
Aren't signatures a bit outdated?
Unread 29-01-2007, 16:35
Electrical Engineer
Rookie Year: 1995
Guy,
This may sound simplistic but I have seen people do it...
When you plug in the DB9 connector to your PC, did you unplug the TTL serial communication cable between RC and CMUCam? You can only have one plugged in at a time.
Also, are you sure that you have a fully charged backup battery? You can get a green light and have a low battery...
Mike
Mike Betts
As easy as 355/113...
Unread 29-01-2007, 16:50
FRC #1574 (MisCar)
Im such an idiot.... I forgot to disconnect the TTL cable
I'll connect it without the TTL cable tomorrow morning (It's almost midnight here...)
Thanks a lot,
Guy
Visit our website:
www.miscar1574.com
Unread 29-01-2007, 17:19
Electrical Engineer
Rookie Year: 1995
Guy,
You are no such thing. I knew about this because I have done it, more than once, in the past...
Regards,
Mike
Mike Betts
Db9 port GOshin Programming 1 02-02-2006 21:39
Camera DB9 / Calibration Port roboticsguy1988 Programming 10 26-01-2005 14:15
DB9 Adapter Vienny Nguyen Robotics Education and Curriculum 7 22-12-2003 16:08
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
Ever seen this serial port problem before??? Aidan F. Browne Programming 5 05-02-2003 12:03
