Go to Post I think we have officially reached the stage of having too much time on our hands. - Koko Ed [more]
Unread 29-01-2007, 18:45
Amisca Amisca is offline
FRC #0538
Amisca is an unknown quantity at this point
Help with Compressor please, sir!
We are using an onboard compressor with the robot. The compressor's wires are fed directly into a spike where it then leads to the power distribution for the ground and a 20 amp fuse for the hot. Is there something wrong with that set up?
Unread 29-01-2007, 18:47
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: Help with Compressor please, sir!
You can just run the ground to the distribution block, as well... and that would probably simplify things...
Unread 29-01-2007, 18:55
Electrical Engineer
Rookie Year: 1995
Amisca,
What you have done is 100% correct. The software in the RC controls the compressor. The following lines of code are from the IFI default code, file user_routines.c, lines 274 and 275:
  relay8_fwd = !rc_dig_in18;  /* Power pump only if pressure switch is off. */
  relay8_rev = 0;
Note that this code presupposes that you have connected the compressor control to Relay 8 and the pressure switch to Digital Input 18.
I also strongly recommend that you replace the 20A CB in the Spike with a 20A CB as per <R65>.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 29-01-2007, 18:59
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
I think you mean replace the 20 amp fuse in the Spike with a 20 amp circuit breaker
Unread 29-01-2007, 19:01
FRC #0538
We do have the sensor plugged into dig io 18 and the spike into relay 8, yet the compressor will still not come on, we are using the default code.
Unread 29-01-2007, 19:17
Electrical Engineer
Rookie Year: 1995
What the other Mike said...
Check the fuse in the spike. It may have already blown. The problem is the inrush current of the compressor.
Mike
Mike Betts
Unread 19-02-2007, 16:19
jdejoannis jdejoannis is offline
FRC #1845
jdejoannis will become famous soon enoughjdejoannis will become famous soon enough
Um, the breakers are too large to fit into the spikes. Is there a special breaker for the compressor spike that I don't know about? Another idea is to use a 40 amp fuse in the spike which is fed from a 20 amp breaker on the breaker board.
Jason
Unread 19-02-2007, 16:21
BBnum3's Avatar
BBnum3 BBnum3 is offline
Ridiculously proud of MN First
AKA: Nat Thompson
FRC #1816 (The Green Machine)
BBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to behold
Send a message via AIM to BBnum3
The 20 amp breakers actually do fit inside of the Spikes, and this is the way you should set up your compressor. We blew 3 or 4 fuses before we installed the 20 amp breakers in the Spike, and we haven't had any problems since.
Founding member of Team 1816.
Unread 19-02-2007, 17:04
Amisca,
As with all RC controls, the robot must be connected to the OI (either by tether or established radio link) and it must be enabled in order for the compressor to start. Double check the PWM cable as well, if everything else is correct. The cables pull out very easily and the correct polarity is critical for operation.
1482 Help with Compressor Rinaldi 427 General Forum 7 31-01-2007 07:46
somebody help me with my compressor please royboards05 Pneumatics 4 19-02-2005 00:38
Help With Compressor Code fred Programming 6 21-01-2005 17:40
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
