Go to Post For our next exercise, we should define Beauty and Truth. :) - Taylor [more]
Unread 29-01-2007, 17:52
Mark Deutsch Mark Deutsch is offline
FTC #1849
Mark Deutsch is an unknown quantity at this point
Leaky Valves
We're trying to assemble our pneumatics system, but we're only able to get pressures up to 20 psi. We can hear and feel air escaping from the double solenoid valve, but we're not sure how to stop it. Any suggestions?
Unread 29-01-2007, 17:59
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Leaky Valves
Without seeing how you assembled them after you replaced the 24vdc solenoid with the 12vdc solenoid (You did replace the 24vdc solenoid with the 12vdc solenoid as instructed didn't you?), I can only guess that the gaskets were not replaced properly. Dis assemble them and verify the correct positioning of the gasket(s).
Unread 29-01-2007, 19:07
Nate Laverdure's Avatar
FRC #2363
Re: Leaky Valves
Soapy water is great for solving this problem!
Get a cup of water, mix in a little liquid soap, and drip it over all of your pneumatic connections with your fingers. Don't use too much-- you only need a little. Turn on the air, and watch as all of the leaky connections blow lots of soap bubbles!
We got our system from 40psi to 120 using this method.
Unread 29-01-2007, 20:03
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Leaky Valves
Other possible problems are that you didn't wrap your fitting with teflon tape. And I think the solenoids leak if you hook them up the wrong way around. But I might just be lumping them in with the regulators on that one.
Unread 29-01-2007, 20:12
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Leaky Valves
To echo what Kevin says. The Teflon tape, when used correctly, works wonders.
Unread 29-01-2007, 20:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Leaky Valves
there are two really tiny phillips head screws on top of it. Try tightening those. If you ask me, it is a poor design, and there should be 4 screws. But, they will hold pressure with the gaskets installed correctly and those 2 screws tight.
Unread 29-01-2007, 21:36
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Re: Leaky Valves
With pnuematics there is a "just right" spot. It can't be to tight and it can't be to loose (this goes for both fittings and solenoids).
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 29-01-2007, 22:57
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Leaky Valves
The valves are air-operated pilot valves. Unless there is a certain pressure in the system, your valves cannot switch to one position or the other, and someone must have turned the little 'knob' to move the valve before there was pressure.
To reset the valve, you need to build up pressure. Simply place a finger over the valve vent (the one with nothing connected and a lot of air escaping), you can easily hold in the pressure, and the valve will self-reset at about 30 PSI.
Write back if that's not it.
Don
Unread 01-02-2007, 12:44
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Leaky Valves
some things to check, in a slow, methodical order.
1. be sure your regulators are not set to limit the system to a lower pressure.
2. take the valve bodies off of the base units. be sure the thicker gasket was used. it will have two holes in i for the screws. (it you do not have a set of miniature screwdrivers, buy a set just for the pneumatics).
3. Remove the fittings and carefully clean the teflon tape off of them. clean out the threads as well, but be very careful.
4. Wrap the fittings with one wrap of tape and then install them. Finger tighten and then use wrenches and carefully tighten.
One key is to take your time. Find a table and sit down and relax. If you rush, you will be doing it all again.....
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 16-02-2007, 15:07
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Re: Leaky Valves
Suggestions:
1) If it is leaking between the valve body and the manifold, make sure you are using the right gasket!
There are two gaskets in the assembly kit, as this is a generic gasket set that covers many different manifold/valve combinations. If you use the wrong one, it'll leak.
2) If it is leaking somewhere around the fittings, the most likely causes are:
a) improper fitting tightening
b) improper Teflon Tape technique (winding in wrong direction, too little, too MUCH, or improper placement - it should start one thread back from the end, wrap clockwise [when looking at the end of the fitting], and I get best results with about 1.5-2 full wraps.
c) bad threads on the fitting and/or the manifold - can be caused by cross threading, overtightening, etc.
d) improper trimming of the tubing before insertion into one-touch push fittings - the end must be clean, cut at 90 degrees (no "Julianne" chef cuts!), and have no nicks or burrs.
e) improper seating of the tubing in the push fitting. When pushing in, it should first resist, then seat with a slight "snap in" feeling.
f) Damaged retainer in the push fitting - often cause by someone improperly removing the tubing previously (pulling the tubing out without pushing in the ring). Replace the connector.
You can easily diagonse leaks by spraying all connection seams lightly (while they're under pressure of course!) with either Windex, or water with a bit of detergent in it, placed in a pump sprayer. Leaks will bubble. (You can get commercial "leak detection fluid" at any hardware store, but this is cheaper, and faster.)
I hope this helps!
- Keith McClary
Chief Engineer, Team 1502 "Technical Difficulties"
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
solenoid valves? brian1717 Pneumatics 2 07-01-2007 15:28
Cylinders + Solenoid valves Greg General Forum 2 28-01-2003 09:29
leaky pnuematics???? archiver 2001 1 24-06-2002 02:18
5 cylinders, 4 electronic valves Wayne Doenges Technical Discussion 5 27-01-2002 16:14
Leak of FIRST Valves Andy Baker Rumor Mill 0 12-10-2001 23:20
