Go to Post Belts are a fine way of transferring power in a robot. Like chains, gears, drive shafts, viscous couplings or any other means of transmission they require some care and attention on you're part. But no one said this robot stuff was going to be a cake walk. - Andy A. [more]
Unread 11-01-2007, 18:03
yarb65 yarb65 is offline
Coach
AKA: T Bray
FRC #3189 (Circuit Breakers)
yarb65 has a spectacular aura aboutyarb65 has a spectacular aura about
Camera HELP!
How did you get the Robot to "follow" the green light!
All i can do is get the camera to follow not the whole robot....
HELP!
I have used both MPLab and Easy C
2013 Sacramento Regional Winner (3189,701,2489))
2012 Israel Regional Winner (1662,1690,1937)
2008 Sacramento Regional Winner (1662,115,2122)
2006 Sacramento Regional Winner (1662,852,1726)
Unread 11-01-2007, 18:06
Bharat Nain's Avatar
Re: Camera HELP!
You will have to program as in write code to that actually responds to the information you get from the camera. If you're using Kevin Watson's code, you get information such as blob size, dimensions and position of the light. You can use that information to track your robots position in respect to the light. Good luck.
More resources at: www.kevin.org/frc
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 11-01-2007, 18:41
Eric W. Jones's Avatar
Eric W. Jones Eric W. Jones is offline
Rack & Roll, baby!
FRC #1646 (Precision Guessworks)
Eric W. Jones will become famous soon enoughEric W. Jones will become famous soon enough
Re: Camera HELP!
the camera includes a servo-type meter that allows you to track the pan/tilt axis. The way you would make the robot follow the green light would be to find if the camera is left or right from center and have the motors turn right or left, respectively. It's fairly simple. PM me if you need more information or a coding example.
2006 Boilermaker Regional
2006 Buckeye Regional - Third place overall
2006 Atlanta Finals
2006 IRI
2007 Boilermaker Regional
2007 St. Louis Regional
2007 Finals (hopefully )
2007 IRI
Why, yes. I do know what I'm doing!
Unread 11-01-2007, 20:33
Coach
AKA: T Bray
Re: Camera HELP!
ok...... so what variables apply here to get the motors to respond...
and does anyone have a clue in using easy C?
(I like easy C because it helps reduce the chance for error.....)
Unread 11-01-2007, 20:40
Re: Camera HELP!
I would like to point you to a few resources: http://www.chiefdelphi.com/forums/sh...ad.php?t=30976 - that thread is for people who are getting started with programming.
http://www.chiefdelphi.com/forums/fo...play.php?f=144 - that is where you will find posts regarding the camera.
There are many sub forums dealing with different aspects of programming including easyC.
Please visit those pages and it will answer most, if not all of your questions. Use the Search function above for specific information on a subject. Good luck.
-= Bharat Nain =-
Unread 29-01-2007, 21:58
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
Re: Camera HELP!
Hey Eric would you be able to post some coding on how you would be able to track the light by moving the robot, because I have been reading some of the posts and some people are saying to use trig. functions to calculate the movement of the robot towards the light. But I thought there would be an easier way. So if you would be helpful and maybe post a code to help me out.
Camera help needed bluisnake Programming 9 08-08-2006 14:58
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
camera help! |20807 61|2|_ Programming 5 08-01-2006 14:44
camera help needed Anton Programming 0 17-02-2005 06:52
Lost Camera- HELP archiver 2000 0 23-06-2002 22:41
