Go to Post ANY team is capable of producing a winning design. This does NOT require anything more than brainpower, and time. - Racer26 [more]
Unread 29-01-2007, 17:42
LieAfterLie's Avatar
LieAfterLie LieAfterLie is offline
FRC #2028
LieAfterLie is an unknown quantity at this point
Evaluation Board Gyro
What exactly is the difference between a normal gyro and the evaluation board gyro? Can you do everything with the normal as with the EB gyro?
Specifically ADXRS150 and ADXRS150EB, as ADXRS150 is what you can get free in the KOP (and what we already have).
From Kevin.org I got "They all come in a package that's too small to work with, so it's best to purchase the evaluation board version of the gyro."
EDIT: Same thing for accelerometers, as I'm going to depend on the gyro, accelerometer and camera alone for autonomous.
Unread 29-01-2007, 17:52
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Evaluation Board Gyro
The evaluation board is a PCB with the accelerometer mounted to it, and maybe a few passive components, so you don't have to solder a bunch of tiny bits yourself. It's definitely a lot easier to work with.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 29-01-2007, 19:08
FRC #2028
How hard would it be to use the non-EB gyro? What exactly would you have to do to interface with it the same way as the EB gyro? And does its accelerometer completely replace the KOP accelerometer? (It's a 2-axis I think.) What do the passive components include? Are there any functional differences? And what exactly is 'easier to work with'? I really tried, I can't find anything definitive online.... Links would be just as appreciated as continued info.
Thanx in advance
Unread 29-01-2007, 19:21
Thanx in advance
Here is a link to the product page for they gyro from Analog Devices: http://www.analog.com/en/prod/0%2C28...S150%2C00.html
From there, you can find out a lot more info about the chip itself and the evaluation board, including what is included on the evaluation board.
The standard chip is packaged in what is called a ball grid array (BGA). The pads are located underneath the chip and are impossible to reach with a soldering iron. You need specialized equipment in order to solder a BGA.
Unread 29-01-2007, 22:28
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Definitely go with the evaluation board. It comes preassembled with the proper set of capacitors and other doo-dads that make it ready to use. Otherwise you have to read through the spec sheet for the gyro chip and figure out how to set up. Why bother?
Unread 29-01-2007, 22:48
robind robind is offline
FRC #0675
robind is an unknown quantity at this point
On the board that FIRST sent us, we're supposed to connect three of the pinouts to the analog inputs on the FRC. That was easy.
But we're also supposed to jumper something on the board. I'm a bit confused as to what exactly we're supposed to jumper. Can someone help me out?
Unread 30-01-2007, 00:47
Jared Russell's Avatar
Taking a year (mostly) off
I don't recall having to jumper anything. It should work out of the box.
Unread 30-01-2007, 10:56
AKA: Dan
Actually you do have to do a little wiring, it's still much easier with the eval board. Here's what you do (hopefully I'm remembering correctly). Below is the link to the spec sheet for the eval board for the 300 deg/sec model. Wiring is the same for the 150 deg/sec. Under the heading "Circuit Description" it sort of gives you clues to how to connect the thing.
http://www.analog.com/UploadedFiles/...XRS300EB_0.pdf
Mounting eval board:
1. Use a project circuit board from Radio shack. Doesn't have to be big.
2. Solder a wire from pin 1 to pin 13. This is your jumper.
Now you need to connect your PWM wires:
1. Black wire is ground, connect to either pin 8 or pin 12 as they are bridged in the EB.
2. Red wire connects to pin 1 or pin 13 (the same pins you jumped).
3. White wire is for the signal. Connect to the rate out pin (pin 2).
This is the simplest implementation and seems to work ok for us since we don't have any electrical engineers on the team. Further wiring can be done to help bias the output based on temperature and reduce noise, etc. but we found it to be unnecessary for the short duration of the competition.
Hope this helps a little!
Unread 30-01-2007, 12:08
FRC #0675
Okay, so I figured it was 1 and 13 on the diagram in that pdf (I actually already had that pdf open ), but I can't seem to figure out what that physically translates to on the board first sent us. Does anyone have a picture of their jumpered circuit?
Unread 30-01-2007, 13:13
AKA: Dan
Ok, I think we need some clarification. The 150 deg/sec gyro that FIRST is providing shouldn't require any jumpering. You need TWO pwms, one for the yaw rate signal, the other for temperature correction signal. The temperature correction is handy because the yaw rate gyro outputs a voltage (0-5volts) proportional to the rate of twist. At 0 deg/sec the output is nominally 2.5 volts. Temperature makes the 0 point drift up or down. So in competition it is possible that the gyro temperature may change and thus throw off the reading.
Now what I was talking about for jumpering is the Eval board you can order directly from Analog Devices, which is what the supplied link is describing. The drawing shows pin 1 and pin 20. The rest of the pins are numbered counter clockwise (looking from the top of the board, not the pin side). The EB has pin 1 printed on the board.
Uh does this help or make it even more confusing?
Unread 30-01-2007, 14:45
FRC #2028
How exactly would you hook up the normal gyro and how impossible is it?
SEMPER UBI SUB UBI
Unread 30-01-2007, 15:14
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
How exactly would you use the normal gyro and how impossible is it?
You can use the gyro with code created by Kevin Watson, available at http://kevin.org/frc. Readme files included in his code instruct you on what needs to be done to get the gyro working, and it is pretty much as easy as following those directions to be able to use it (though it will probably take a good 30 minutes or hour to get the gyro working if you've never done it before).
As for what you can use the gyro for, that's left up to your team's imagination.
Unread 30-01-2007, 15:24
FRC #2028
And is there any difference between the programming for the normal gyro and the EB gyro?
SEMPER UBI SUB UBI
Unread 30-01-2007, 16:02
AKA: Dan
programming wise if you use the AnalogDevices gyro it will be the same. I believe Kevin Watson's code is set to use both the 150 deg/sec and the 300 deg/sec gyro, if that is what you are using. If using EasyC I think you need to scale the output by a certain factor to get the correct output. It depends on which model you are using.
Unread 30-01-2007, 22:48
FRC #0675
So do I have to wire all six pinouts for the one that FIRST provided to work? I only wired the "Twist" pinouts. And it wasn't working. Maybe I should wire up the other pinouts
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Gyro magical hands Programming 2 14-01-2005 20:57
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
Gyro archiver 2001 2 23-06-2002 23:11
