Go to Post Gotta love it... FIRST's GDC...providing entertainment to loads of bored Bostonian FIRST'ers on a friday night. - Andy Grady [more]
Unread 29-01-2007, 19:41
iwdu15 iwdu15 is offline
FRC #0811
iwdu15 is an unknown quantity at this point
GTS strange behavior
Hi, im working on the GTS code for our teams robot and ive hit a roadblock of sorts. I have tried using the 2007 default code for the GTS and put printf statements in the encoder initialization function, yet nothing is ever printed. the interrupt handler is also never executed. there is no "Phase B" code and the encoder is wired into the Digital Input 1 input. The Initialize code for the encoders is in the User_Initialization function:
printf("Initializing Encoders......\r\n");
Initialize_Encoders();
printf("Encoders init done!");
both printf statements are executed, however the InitializeEncoders function is not executed:
//first few lines
void Initialize_Encoders(void)
printf("initializing encoder 1 \r\n");
//rest of init code here...
whats going on? Thanks
--iwdu15
--Team 811
Unread 29-01-2007, 19:49
Electrical Engineer
Rookie Year: 1995
Re: GTS strange behavior
Maybe it's just me. I do not know of any "2007 default code for the GTS". Please provide a link to the code you are trying to use.
Mike Betts
As easy as 355/113...
Unread 29-01-2007, 19:58
FRC #0811
oops sry, typo, i meant the 2006 code at: http://www.kevin.org/frc/ ....sry about that
Unread 29-01-2007, 22:23
Electrical Engineer
Rookie Year: 1995
I assume that you are using Kevin's FRC_encoder.zip files.
I also assume that you know what a statement like
"#ifdef ENABLE_ENCODER_1"
does and that you placed your printf outside the compiler directives.
Am I on the right track?
Mike
Mike Betts
Unread 29-01-2007, 22:45
...I have tried using the 2007 default code for the GTS and put printf statements in the encoder initialization function, yet nothing is ever printed.
Does the source code file with the encoder initialization function #include <stdio.h>? If not, the printf won't actually produce any output.
Unread 30-01-2007, 09:36
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
A few pointers:
Kevin's code uses the C Library printf with his buffered, interrupt driven serial port routines. The default code has it's own printf and serial port initialization. You need to use one or the other but not both.
Kevin's encoder code is for a quadrature encoder. The gear tooth sensor is not a quadrature encoder, so there is no Phase B signal. This means that you cannot determine the direction of rotation from the gear tooth sensor.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 01-02-2007, 18:46
FRC #0811
hi, thanks for the replies...i already took out the PhaseB stuff and i did include stdio.h....so thats not the issue. il try checking the printf statements and use the way included in the GTS code and get back to you....thanks for the help so far
--iwdu15
--team 811
How the GTS works? Bomberofdoom Programming 6 25-01-2007 21:46
GTS Counting gnirts Programming 13 21-04-2006 21:15
GTS code Problems caderader Programming 8 13-02-2006 19:23
Strange Behavior Gary Bonner Control System 17 09-11-2005 19:01
